Which Port Do I Use To Put Freon In 2006 Ford Escape - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-25-2011, 06:37 PM   #1
which port do i use to put freon in 2006 ford escape
theres a small aluminum tube and a larger one but both have ports....
brenda o is offline   Reply With Quote
Old 07-25-2011, 07:06 PM   #2
NACE Coating Inspector
mustangmike3789's Avatar
if you are using one of those r134a kits, they will only fit on one side so you cant screw it up.
mustangmike3789 is offline   Reply With Quote
Old 07-25-2011, 08:32 PM   #3
ukrkoz's Avatar
Rewards Points: 990
always low side. make sure you use freon/oil mix and DO NOT OVERFILL the system, or it will stop working. plastic caps on ports should have large L and H for low and high on them.
ukrkoz is online now   Reply With Quote
Old 07-25-2011, 09:34 PM   #4
If he can't figure out what port to use, like he has a clue if he is going to over fill it, why even make him worry. Go spend 70.00 and have it done at a shop.
D-rock is offline   Reply With Quote
Old 07-25-2011, 11:32 PM   #5
Jack of All Trades
Yeah, always use the Low pressure side, cap may or may not have a big "L" on it but whatever kit you have to add freon with should only fit on one not the other. Also the Low pressure hose I think is always the larger hose, at least on the cars I've worked on.
DoctorWho is offline   Reply With Quote
Old 07-26-2011, 06:34 PM   #6
thanks for the info....not a "he" doing this though, im a "she" and with your guys help will get it. fyi though, it has a gauge on it, comes with the oil mix and it says to check it first to see how full it is then add so don't think it will "overfill" but i will err on the side of caution. just needed someone looking over my shoulder with this... i checked it before posting, i just didn't know which tube was the low side......i'll let you know when i'm finished how it worked
Old 07-27-2011, 02:04 PM   #7
ukrkoz's Avatar
Rewards Points: 990
I am watching over you, no worries. Be PROUD of yourself, and no need to explain your gender. Those who will take THAT under consideration are not worth paying attention to anyway.
just last word. Make sure you have that connector on the port REALLY tight and wear thick gloves. Refill cans you buy in stores are notorious about being loose on connectors, then you spill more, than goes in. Plus, you frost bite your fingers.
Give it short bursts and re-check on function/pressure. If by any unlucky chance, you overcharged and system locked on you, you can, ahm, bleed some out via port. Not nice to do, but is effective. Just like you bleed air out of your tire.
Old 07-30-2011, 01:56 PM   #8
did get some in, about half the can and it started out all nice and cool but its still not cold. going to have garage look at it. theres got to be a leak if it didn't stay cold... but had it worked, would have saved self some... thanks for the help and confidence
Old 07-31-2011, 01:38 AM   #9
Rewards Points: 1,010
I bought a can of 134a the other day for my van....WHOA has the price gone up on that stuff!!
spaceman spif is offline   Reply With Quote
Old 08-06-2011, 08:56 PM   #10
A Little Of Everything
Rewards Points: 1,364
That's right.
In addition, a lot of cars have plastic port covers - one of which will have "H" and one "L" imprinted. Not too tough to figure out.
DrHicks is offline   Reply With Quote
Old 08-06-2011, 08:59 PM   #11
Around here it's $15 for a 12 ounce can.
*I was in Northern Minnesota this week, and noticed that the same stuff was $8.99 up there. I suppose supply & demand had something to do with it.
2006 ford escape transmission problem olivia 123 Automotive Repairs 1 07-25-2011 03:36 PM
Ford Escape brenda o Automotive Repairs 2 04-28-2011 10:25 PM
Repair cracked "plastic" bumper cover? (Ford escape) rossl56 Automotive Repairs 6 08-27-2009 08:03 AM
