Permatex Battery Protector SA-9 - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-13-2010, 07:28 PM   #1
Rewards Points: 900
Hi;
Can someone tell me how this product is supposed to be used?
Should I spray it onto the exposed terminals before I connect the battery, or after it is all connected?
Reason I ask is that I have seen the kind of grease that you are supposed to apply to the terminals and clamps before connecting. But this stuff comes out looking like a coating that is intended to protect against corrosion by sealing the metal parts, so it would probably interfere with electrical connection.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 12-13-2010, 07:39 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
the directions (found here)
aren't real clear either but there is a drawing that shows them spraying a terminal with the cable clamp installed. Given the material, I would think it was to be applied to the completed assembly. The ingredients do contain some insulating material so it would tend to cause a poor connection between the terminal and the clamp, IMO.
Old 12-13-2010, 09:12 PM   #3
Rewards Points: 900
Thanks nap;
That's kind of what I figured, but since I had seen something in a blog or something about battery installation, they mentioned something that should be applied to the terminals, and gave me the impression that it was to help with electrical contact. Probably not the Permatex stuff though. I have read about people using Vaseline, which I think gets applied onto the terminals and clamps before the installation.
I think that Permatex should have made the instructions on the can a bit clearer. I saw the illustration you are talking about when I searched online.
There is nothing at all on the OEM battery or clamps, and I don't see any corrosion. Maybe I didn't need the Permatex at all, but it was cheap.
FW
Old 12-13-2010, 09:16 PM   #4
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
is this the stuff that comes in the aerosol can and comes out red? If so I used to use on my Jeeps. All I did was attached terminals, than sprayed over the works. Seemed to work well, never had any corrosion issues that i recall
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 12-14-2010, 01:57 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,706
Ayuh,... Nothing should be applied to the terminals before the hookup...
It should be Clean metal to Clean metal...
I use common Grease to slather the terminals, After they're attached...
No need for anything Special...
I Never, Ever get corrosion...
APC Battery Backup - Extending Run Time with BIG Battery Bank homerb PC Repairs & Upgrades 31 05-03-2012 05:40 PM
Has anyone tried this way of fixing a dead cordless tool battery? BJLower Electrical 11 02-01-2010 01:31 PM
Old UPS to car battery? pcampbell Electrical 8 01-20-2009 05:34 PM
Milwaukee v28 Battery Life r62ewa Tools 12 12-04-2008 06:58 PM
Ryobi 12v battery system JElson Tools 3 10-11-2008 09:50 PM
