Pcv Valve? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-26-2007, 01:27 PM   #1
pcv valve?
i have went round and round with this but can anyone tell me where the pcv valve is on a 2002 chevy s-10? (6 cylinder, 5 speed manual). i have always been told it is around the valve cover but cannot seem to locate it!!!
please help. put my frustration to rest!!!!!
reds_21
reds_21 is offline   Reply With Quote
Old 11-26-2007, 02:06 PM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,360
I take it that it's not sticking out of the valve cover?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 11-26-2007, 02:18 PM   #3
no, if it is, it certainly isn't obvious!!!
Old 11-26-2007, 03:00 PM   #4
I have gas!
I don't know much about the S10 and I don't know how much help this is but are you able to track backwards from the air cleaner assembly?
Old 11-26-2007, 03:10 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
According to Autozone.com:
PCV Valve
On your 2002 Chevrolet Truck S10 P/U 2WD 4.3L SFI , the PCV Valve is located:
Under hood, driver side, upper engine area, mounted on valve cover
If it's not there, I've got a manual on this I can check for you
slickshift is offline   Reply With Quote
Old 11-26-2007, 03:21 PM   #6
I have to think back a couple years here, but on my 95 S-10 TBI V-6, the PCV valve was on the passenger side of the engine, on the valve cover, or maybe just below it/on it's side. It had a rigid tube attached to it, which ran forward. It was pretty obvious. Have you bought a new one, so you know what you're looking for?
Do you have the direct fuel injected engine, or the Throttle Body Injection engine?
NateHanson is offline   Reply With Quote
Old 11-26-2007, 03:46 PM   #7
is there any picture that someone can post of this area? i have a truck manual that says its on the drivers side as slickshift has stated but i am not seeing it.
what is bringing this up, is that i bought a pcv valve from the local auto parts store about a year ago since i was doing a tune up of my truck and the auto parts store catalog showed the pcv valve i needed along with a model number. so i bought it and have no clue where it goes. i used to have a chevy corsica and i knew where that location was but im not seeing the area to be as obvious.
i will post a picture tonight of the area under the hood and maybe someone can see it from the picture.
im not auto savvy so im not sure the difference between direct fuel injected engine, or the Throttle Body Injection engine
Old 11-26-2007, 03:53 PM   #8
I don't have that truck anymore, so I can't take a picture for you.
If the last letter of your VIN is a "Z" then it's the TBI engine, if I recall. If that's the case, then I think you might have the wrong part. When buying parts for this truck you have to specify the TBI or "VIN Z" engine. The TBI engine has a big round air filter on top, like a carbuerator would have on top of it. I'd guess that the direct injection engine would have a flat rectangular air filter, although I haven't seen that engine myself.
Old 11-26-2007, 05:48 PM   #9
I have gas!
Do any hoses go into the top of the valve cover on the driver's side?
ball valve leaking bwall Plumbing 10 12-31-2012 07:25 PM
Replace toilet water shutoff valve abastin Plumbing 14 02-14-2011 03:41 PM
Toilet valve replacement? steve771 Plumbing 18 07-10-2007 10:50 AM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 02:17 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
