Parking Pawl On '84 K10 4x4? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-01-2010, 02:50 PM   #1
Rewards Points: 260
Parking Pawl on '84 K10 4x4?
Has anyone ever done this? I'm shopping this truck right now and it needs a new parking pawl. It doesn't go into park and has to be stopped with blocks. Has anyone ever done this repair? Thanks!
Jesse
jpearson311 is offline   Reply With Quote
Old 07-02-2010, 12:09 AM   #2
cowboy dan's Avatar
Jesse
if you are refering to the pin the locks the tranny while in park? bad day for you if you already bought it. if you did, then use the e-brake alot more. and there is more than likely bigger problems in the near future.... i know, i'm just full of dome and glume.
cowboy dan is offline   Reply With Quote
Old 11-02-2010, 08:27 PM   #3
Rewards Points: 150
Jesse
Pp on ford tranmissions is easy. Pull pan on tranny after draining. Pawl will be right on shift linkage looks like a saw tooth. Breaks when people slam into park when rolling or parking overloaded on hills withoit eb,rake. These are a description of a C6 tranny. Not sure what tranny you ha e but probally conected to shift linkage.
ianc435 is offline   Reply With Quote
Brick Parking Pad joon Building & Construction 0 06-15-2010 06:04 PM
Changing from shrubs to parking pad irish56e8 Building & Construction 1 06-09-2010 08:35 PM
Garage parking post Denk General DIY Discussions 6 01-15-2008 07:56 PM
Pouring a concrete slab - Do I need a 4" gravel base? tokuzumi Building & Construction 2 11-27-2007 07:40 PM
Basement leaks in brick wall Nick General DIY Discussions 8 07-18-2006 04:29 PM
