Painting A Car - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-09-2013, 09:52 AM   #1
Jack of all Trades
lifestooshort81's Avatar
Rewards Points: 77
Painting a car
Hi folks,
I just "inherited" a 1998 VW Jetta. Body is in pretty good shape (no rust) but the paint is definitely In need of refreshment. I've painted a car or two in the past but that was close to 13 years ago. I was debating on having maaco do a cheapy re-paint for $330 but when I went and had them look at it, of course they found things to jack up the price. My total estimate was around $650... That being said I'm toying again with the idea of just doing it myself.
I guess my question here is has anyone painted their own car parts and what kind of paint did you use? I have a sprayer and know a little about prep-work but not sure on the paint. Maaco was just going to use a straight enamel. I think for the ease of doing it myself I would go the same route.
Thoughts???
Thanks,
Al C
lifestooshort81 is offline   Reply With Quote
Old 08-09-2013, 09:58 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
I would suggest finding a buddy who does it for a living and wants to make a few bucks on the side.
I've done it as well. A lot has changed....the chemistry...the tools....if you want it right, by the time you get all the equipment you need and spend the time....$650 is cheap. Do you have a point booth? With water filtration? Do you know how much hardner to put in the paint? Is your air compressor totally moisture free? A proper air dryer will cost you $600.
If you want to save money...do all your on prep...then let someone else paint it.
Matco is not going to pull off trim...they just tape and shoot. If it's mine, if it comes off...I take it off...
Old 08-09-2013, 10:11 AM   #3
Still Decompressing
Rewards Points: 273
What quality level are you looking for? There are some folks that have gotten surprisingly good results rolling on rustoleum.
caveeagle is offline   Reply With Quote
Old 08-09-2013, 08:51 PM   #4
my girlfirnd had a vw bug that someone painted with a brush. was probably house paint too
Old 08-10-2013, 07:54 AM   #5
Jack of all Trades
Rewards Points: 77
I'm looking for something a little nicer than a rustoleum roll on finish. LOL I actually painted my work truck with rustoleum's hammered paint...using a roller as an applicator. It surprisingly came out amazing. but that's a work truck, this is a car. I do need something nice for those far and few times I may have a date to take out LOL!!! Then again I'd be hoping my date actually like trucks and want to take my pickup
...but on a serious note I would like the car to stay nicer looking.
Ill look into prepping it myself. Thanks!!!
Old 08-10-2013, 07:41 PM   #6
ukrkoz's Avatar
Rewards Points: 978
try search engine here.
Someone painted entire car, for a fraction of the cost, with roller. Seriously. Guy had to spend a ton of time sanding/polishing/buffing, but results were actually quite good and cost was around $100.
ukrkoz is offline   Reply With Quote
Old 08-11-2013, 09:32 AM   #7
Still Decompressing
Rewards Points: 273
I spend a lot of time working on and around vintage mustangs. (mine is a '67 vert). The serious restoration guys have a hard time finding modern paints that give you the correct look of an original Ford Paint Job. Actually most of the modern stuff will look 'too' good. There are a couple of guys that used the Rustoleum and got very close to the look of an original 60's factory job.
Old 08-11-2013, 06:14 PM   #8
Too Short? Cut it Again!
Before you rush off to paint this thing, have you tried detailing a small piece of it out with rubbing and polishing compounds first?
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 10:42 AM
Newby painting over existing fascia, beadboard appledeco Painting 3 07-26-2009 05:52 AM
Painting over a sponge painted wall Snowdog Painting 3 03-16-2008 11:13 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
