Paint Job-HOW!? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-28-2008, 10:25 AM   #1
mbad7's Avatar
Paint job-HOW!?
Hi! Im new to this forum so i dont know if the topic had already been brought up.... Im looking to do the paint job on my BMW myself,but i need advice on how to prep the car,where to start,what kinda paint to use,basicly everything,so id be grateful if someone would describe the process,main guidelines,some important details maybe,etc... Thanx
mbad7 is offline   Reply With Quote
Old 03-28-2008, 05:43 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,736
Ayuh,....
How well Equiped is your Shop,..??
Air compressor,..??
Sanders,..??
Paintgun,..??
Buffer,..??
Resperator,..??
Paint Booth,..??
Old 03-29-2008, 07:52 AM   #4
Hey Mbad ,no Disrespect But, Maybe You Should Work Your Way Up To That. If Your Asking Those Kind Of Questions , Your Not Ready.
CPETRO is offline   Reply With Quote
Old 03-30-2008, 05:38 AM   #5
You go for it mbad7. Just remember it is only paint and labor.So when in doubt pull the paint gun trigger and worry about it later.Good Luck
mark942 is offline   Reply With Quote
Old 04-13-2008, 08:21 AM   #6
mbad7's Avatar
Thnx 2 all of u Im sanding down the car these days... Will update
Old 04-13-2008, 11:38 AM   #7
Remodeling Contractor
oldfrt's Avatar
Rewards Points: 186
Keep us posted mbad,good luck with your project.
I've painted two of my work trucks with fantastic results.The previous owner of one of them couldn't believe it wasn't professionally done.
I feel more comfortable with enamel that has a hardener added to it.
On my first spray job,I forgot to have a filter on the compressor and all the rust from the tank sprayed onto the surface.I saved the paint job by a lot of wet sanding and polishing,but it ended up mint.
oldfrt is offline   Reply With Quote
Vinyl Paint - PolymatrX - and Siding.... Classic Painting 2 07-23-2008 06:45 AM
What's your "favorite" tip, when using "oil base" paint? Bobrobert Painting 15 01-17-2008 10:36 PM
How should I paint this room? LeroyFrick Painting 8 10-30-2007 05:09 PM
Paint coming off of siding ciera Painting 5 07-01-2007 05:22 PM
