Paint Color - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-23-2016, 08:38 AM   #1
Rewards Points: 736
paint color
For my parents 1998 toyota camry. The side mirror replaced and I used duplicolor. The door sticker says 4m9 and every site I went to says it's cashmere beige metallic and the actual paint dried to darker beige. I used adhesion promoter on black plastic, color and clear coat. Is duplicolor just mismatched or is it a matter of using white primer or something else?
Thanks in advance.
carpdad is offline   Reply With Quote
Old 11-23-2016, 09:46 AM   #2
Rewards Points: 672
Re: paint color
The existing paint is 18 years old and has likely faded quite a bit. I would bet the duplicolor would match what came off the showroom floor.
Give it some time and see what happens.
stick\shift is offline   Reply With Quote
The Following User Says Thank You to stick\shift For This Useful Post:
carpdad (11-24-2016)
Old 11-23-2016, 11:30 AM   #3
Rewards Points: 2,106
Re: paint color
Stick/Shift has a point.
Every light colored METALLIC painted vehicle has faded in a few years from the original , So more than likely your parents car has seen some sunshine in it's 18 years .
Just tell them that you made it that way so that it will contrast better so that they wont knock it off again.
Just kidding, AS I don't know how it came to pass that it needed replaced.
ED
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
Old 11-24-2016, 06:41 AM   #4
Rewards Points: 736
Re: paint color
Thank you for the replies. Problem is, I thought I could reuse the original shell (only the inside bracket broke apart) and removed the mirror and the motor and inside is the same color as the outside. I can't find show room photos for this car but every camry image shows the paint on this car, not the dark beige from duplicolor. I admit every photo could be showing faded paint. I'll try another can and see. I put the new side mirror on and it looks terrible. The cap on the can is original color. What came out of the can is something else.
Old 11-24-2016, 06:51 AM   #5
Re: paint color
HMMM:
Did you shake the can enough to mix it well?
Sometimes those cans sit for a long time and separate.
ED
Old 12-02-2016, 01:03 AM   #6
Rewards Points: 62
Re: paint color
You can usually have a local paint shop color match your car and put the paint in a rattle can for you. It will be about 3-4 times the price of duplicolor though.
Here's my experience with duplicolor color match, it too wasn't an exact match but it's very close.
Joeycarnuba is offline   Reply With Quote
What's the best paint for old aluminum siding? JohnnyBlades Painting 6 05-21-2015 09:56 PM
Welcome to Latex Paint 101 Nestor_Kelebay Painting 60 05-04-2015 12:21 PM
painting advice rizzyboy Painting 10 03-25-2015 01:01 PM
Valspar signature Mroe192 Painting 21 08-18-2012 03:39 AM
