Overheating Issue - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-09-2010, 01:08 PM   #1
Overheating issue
I have a 1993 Mazda Mx-6 that had a head gasket problem in september/november of 2009, so i parked the car.
I finally got an engine replacement (ZE engine = more power) and we installed it into my car ( the engine was known good,low mileage ) and drove around for a week or two until it started to overheat.
We found out that the hose that goes from he intake(i think) to the radiator was squeezing shut, allowing small amounts of coolant through. So we replaced it, still overheating when running for a while..so we replaced the radiator, still overheating when running for a while..
I did a compression test on the engine -all are the same..and what i would expect.
No we just bought a thermostat, hoping it may fix the issue...Suggestions?
Gemini8511 is offline   Reply With Quote
Old 04-14-2010, 12:47 PM   #2
cowboy dan's Avatar
was the engine out of the car when you bought it? or did you hear it run?
you seem to have a pressure problem. check themostat, u might have a blockage in the waterjacket, does the engine blow hot air, warm, cold? what color was the coolant, is there slugge in the bottom or your overflow tank? look for a really dark grey thick spoogy goopy stuff. if you do chances are that engine had barsleak thrown in the rad. that spoog can and will block cooant flow. have u checked the mechanics of the waterpump... simply release the serp belt and wiggle the pully if it rattles at all, get a new one regardless if its the problem or not.
hope i helped
cowboy dan is offline   Reply With Quote
AC condensate issue cleddy HVAC 1 08-02-2009 10:26 PM
Interlock Paver Issue cbadrik Landscaping & Lawn Care 2 07-27-2009 08:29 PM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 04:14 PM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 02:34 PM
Unusual electrical issue LosLobo Electrical 7 11-10-2008 02:44 PM
