Oil Changes Drip On Starter - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-06-2009, 04:25 PM   #1
sweaty
Rewards Points: 276
When I get oil changes, oil drips from the filter area onto the starter motor. On one of my old cars, I had gotten a cover for the starter to prevent it from going bad. Yes, I know the motors are supposed to be sealed and won't get a problem from the oil, but I don't believe it.
Does anyone know where I can get starter covers for my 2000 Ford Taurus and 2001 Nissan Sentra SE?
sweaty is offline   Reply With Quote
Old 08-07-2009, 06:28 AM   #2
47_47's Avatar
Rewards Points: 58
The main reasons for starter failures is a weak battery and excessive heat. Putting a cover on the starter will trap in the heat.
47_47 is offline   Reply With Quote
Old 10-29-2009, 01:48 AM   #3
Drinks Mobil 1 5w-30 oil
COBRA90GT's Avatar
^ What 47_47 said above is true. Try folding up some foil to help "guide" the oil dripping down from the oil filter housing into a drain funnel/pan. Or you may even be able to find an appropriate sized funnel (with tube/hose) that can sit above the starter and catch any excess oil draining from the oil filter area.
COBRA90GT is offline   Reply With Quote
Old 10-29-2009, 06:12 PM   #4
Why is oil dripping down from the oil filter? I would change where I was getting my oil changes done.
merle is offline   Reply With Quote
Old 10-29-2009, 08:08 PM   #5
Well, you should. Sealed motor or not, oil is an elec. insulator.
I'd be more concerned about oil dripping on the exhaust manifold and catching fire.
Old 10-30-2009, 04:17 AM   #6
Are you looking for something like this:
This was made for 2002-2004 Honda CR-Vs. It has a magnet that attaches to the oil pan.
jerryh3 is offline   Reply With Quote
Old 05-12-2010, 11:54 AM   #7
ews
Portlander
ews's Avatar
That happens all the time. These car makers put the filters in some of the worst spots. Just wipe the oil off the starter. You can also try putting a largest plastic sandwitch bag over the oil filter when you crack it so that all the oil drains into the bag instead of going ALL over the place.
ews is offline   Reply With Quote
need advice pinning down existing drip cap balaway General DIY Discussions 2 05-07-2009 05:15 PM
drip cap question marlinpuppy Building & Construction 1 03-17-2009 11:10 PM
Window is 4" narrower than RO, and Drip Cap ? yung-cheng Building & Construction 2 08-07-2008 08:14 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 02:10 PM
Drip Cap or Drip Rail joe3534 Roofing/Siding 7 09-18-2007 03:38 PM
