No Running Lights - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-18-2011, 06:14 AM   #1
No Running Lights
I have developed a problem with my factory installed 7 pin connector on my 09 Titan as I no longer have running lights on my utility trailer. I checked all the wiring on the trailer then when I checked the 7 pin connector with my meter, I get no reading on the running light pin (11 o'clock position). but get a reading on the 12 volt pin (1 o'clock position). I use a four pin connector inserted into the 7 pin connector for my trailer and of course there is no power going to the running lights, but brake and turn signal lights work on the trailer.
Does anyone have suggestions?
johnkenn2000 is offline   Reply With Quote
Old 02-18-2011, 10:06 AM   #2
Rewards Points: 46
Sounds like you know exactly what you are doing, so I hesitate with my first comment, but, obviously, make sure that your vehicle lights are on when checking the the running light terminal in your vehicle receptacle. After that, it sounds like it has to be a loose or corroded connection within the receptacle itself. You probably have a wad of tape around where the wires enter the terminal, but carefully cut it back, and see what you have. If it's simply loose, you're on your way again, but its' very possible that you may need to pick up a new receptacle at your local parts store or dealer. Not that uncommon of a problem. Either way put a bit of dielectric grease, or I sometimes use Vaseline, on everything before you tape it back up. Alos, if it looks like the wires are long enough to do you any good, you may want to unscrew the receptacle from the vehicle, as it may allow you easier access.
The Following User Says Thank You to DexterII For This Useful Post:
johnkenn2000 (02-20-2011)
Old 02-18-2011, 10:15 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 592
Ayuh,... Donno what yer Tow unit is, but check it's Fuses....
Bondo is online now   Reply With Quote
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 10:39 AM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 12:45 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
Added can lights, tripping GFI tandyt Electrical 3 05-18-2008 10:55 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
