#1 |
Nissan Sentra's heat isn't working
I have an 04 Nissan Sentra and something is wrong with the heat. After the car warms up, it still blows, but it doesn't blow hot air. It will however blow hot air from time to time when my foot is on the gas. Any idea what could be wrong with it? Thanks.
Jesse |
#2 |
Could be low on anti freeze, an air pocket in the cooling system, restricted heater core. Start with checking coolant level.
#3 |
Coconut Pete's paella!
Sounds like it could be a thermostat also. If burping the cooling system doesn't work I would buy one. Should be cheap on a Sentra, I used to work on Nissans - what year is it?
#4 |
Jack of all - master none
After checking anit-freeze levels, I would look into the thermostat. When was the last time the thermostat was changed? They are a wear-and-tear part, like tires and windshield wipers - need to be replaced from time to time. I've never done one on a Sentra, but $15 at Autozone/NAPA/etc., 15 minutes and common tools should get the job done on most cars.
#5 | |
A Little Of Everything
Nissan Sentra's heat isn't workingQuote:
The second (less) likely culprit is a vacuum leak, causing your "baffles" to not work properly. Does your heating system respond appropriately when you switch from floor heat, to dash heat, to defroster? |
| The Following User Says Thank You to DrHicks For This Useful Post: | jpearson311 (01-20-2012) |
#6 |
Any verdict ?
#7 |
Nissan Sentra's heat isn't working |
#8 |
Master General ReEngineer
#9 |
#10 | |
There are a couple ways of looking at this. If you're car is on its last leg, and you'll only be driving it for a few more months before it completely dies, fine. There's no reason to spend any money on it. However, if you're to keep driving the car, save up a little money and replace your pump as soon as you can. You know what's coming, so why run the risk of it happening when you're out in the middle of nowhere. |
#11 | |
Jesse |
#12 | |
#13 |
#14 |
#15 | |
Jesse |
| Display Modes | |
| What did I do? Heat Pump isn't working | ChrisDIY | HVAC | 10 | 03-14-2011 04:55 PM |
| Furnace is working but no heat | Lon1974 | HVAC | 21 | 09-12-2010 11:00 PM |
| Heat Pump Woes | Zenica | HVAC | 50 | 01-27-2009 08:37 AM |
| heat pump not working | kyleGR | HVAC | 2 | 05-30-2006 03:35 PM |
| baseboard heat upstairs not working | TraceyLee | HVAC | 1 | 10-23-2005 06:47 PM |
