-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   Nissan Sentra's heat isn't working (http://www.diychatroom.com/f46/nissan-sentras-heat-isnt-working-129764/)
jpearson311 01-12-2012 10:31 PM
I have an 04 Nissan Sentra and something is wrong with the heat. After the car warms up, it still blows, but it doesn't blow hot air. It will however blow hot air from time to time when my foot is on the gas. Any idea what could be wrong with it? Thanks.
Jesse
cjm94 01-12-2012 10:36 PM
Could be low on anti freeze, an air pocket in the cooling system, restricted heater core. Start with checking coolant level.
CoconutPete 01-13-2012 09:53 AM
Sounds like it could be a thermostat also. If burping the cooling system doesn't work I would buy one. Should be cheap on a Sentra, I used to work on Nissans - what year is it?
hyunelan2 01-13-2012 10:12 AM
After checking anit-freeze levels, I would look into the thermostat. When was the last time the thermostat was changed? They are a wear-and-tear part, like tires and windshield wipers - need to be replaced from time to time. I've never done one on a Sentra, but $15 at Autozone/NAPA/etc., 15 minutes and common tools should get the job done on most cars.
DrHicks 01-13-2012 10:30 AM
Jesse
The first most likely culprit is low anti-freeze level. Unfortunately, this could indicate that you either have a blown head gasket and/or a water pump that is leaking (and soon in need of being replaced). It's also possible that you could have a leak in your radiator, or a radiator hose.
The second (less) likely culprit is a vacuum leak, causing your "baffles" to not work properly.
Does your heating system respond appropriately when you switch from floor heat, to dash heat, to defroster?
Carkid0007 01-24-2012 10:20 PM
Any verdict ?
jpearson311 01-25-2012 04:07 AM
Originally Posted by Carkid0007 (Post 833850)
Any verdict ?
There was a small leak in the water pump so I put some stop leak in her and topped off the coolant. So far so good.
Jesse
Bondo 01-25-2012 06:40 AM
Jesse
Ayuh,... You need a New water pump...
jpearson311 01-25-2012 09:49 AM
Yeah, I know. But I'll wait until the damn thing falls off before I put a new one on there. Thanks everyone!
Jesse
DrHicks 01-25-2012 10:07 AM
Jesse
Water pumps are designed to seep a little as they're beginning to fail. You've probably got a couple thousand miles left in your pump.
There are a couple ways of looking at this. If you're car is on its last leg, and you'll only be driving it for a few more months before it completely dies, fine. There's no reason to spend any money on it.
However, if you're to keep driving the car, save up a little money and replace your pump as soon as you can. You know what's coming, so why run the risk of it happening when you're out in the middle of nowhere.
jpearson311 01-25-2012 10:14 AM
I appreciate your input DrHicks, but I'm never in the middle of nowhere. I live in the city. And a city of about 1 million people. Nevertheless, I'll get it fixed, but just not now. Thanks again.
Jesse
DrHicks 01-25-2012 10:37 AM
Jesse
I thought Columbus was - literally - the middle of nowhere! :)
jpearson311 01-25-2012 10:39 AM
Columbus the middle of nowhere? It's the capital city man. It's no NY, but it's definitely a good size city.
Jesse
DrHicks 01-25-2012 10:43 AM
Jesse
I'm kidding. I live in Nebraska. :)
Hey - are you planning to do this job yourself?
jpearson311 01-25-2012 10:58 AM
Yes, I know. I've driven all the way through Nebraska before on I-80 and really, I thought it was quite nice. Anyway, I will probably not do this myself. I hate changing water pumps myself because you have to drain the coolant.
Jesse
