New Rotors On My F150 Were Junk ! - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-22-2009, 02:05 PM   #1
New rotors on my F150 were junk !
I bought 4 new rotors and pads for my 2001 F150. After I finished the job, it seemed just ok. A little shimmy but I passed it off. It wasn't a week later when I noticed how bad the shake was. I put an indicator on the rotors and they were .008, .012, .016, and .020 out ! Sheesh. I could feel it when I WASN'T using the brake. I got them at Brake Performance in California. They sent me 4 new ones but I've got to wonder how long these will stay true. I had to pay to send the bad ones back which kinda sucked. We'll see.
budedm is offline   Reply With Quote
Old 12-22-2009, 02:19 PM   #2
You were expecting something else from generic rotors?
jerryh3 is offline   Reply With Quote
Old 12-22-2009, 02:59 PM   #3
47_47's Avatar
Rewards Points: 50
Did you clean the hubs and the rotor of the cosmoline prior to installation?
47_47 is offline   Reply With Quote
Old 12-22-2009, 03:03 PM   #4
Yes. Everything was clean and all mating surfaces were checked for flatness and burrs. The new rotors are good. Well, the worst one is .006 out. I'm not sure what the tolerance normally is on a rotor but I would think they would be dead straight since they bore and turn them at the same time. So, I'm still not 100% happy with these Brake Performance rotors but at least the truck is driveable.
Old 12-22-2009, 06:16 PM   #5
firehawkmph's Avatar
Rewards Points: 1,864
Bude,
My son is a mechanic, so most of my vehicle maintenance is done at home. In the past I have paid more than double to get Bendix brake rotors and pads because they are made in the states. They would last about two years and then warp and pulse so bad I would have to replace them again. My son usually turns new rotors just to true them up. He justs takes a very minute cut. He also uses a scotchbrite wheel on an air grinder to clean the hub area where the rotor sits. A very thin coat of neversieze between the hub and new rotor and the sliding parts of the caliper keeps them from rusting. I stopped buying the bendix. Our local Advance Auto store stopped carrying them. So now I buy the foreign ones and expect them to do the same thing. In two years I'll be replacing them, but at less than half the price. They don't make them like they used to.
P.S. Buy them local so you can take them back if necessary without incurring the shipping costs.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 12-23-2009, 06:21 AM   #6
47_47's Avatar
Rewards Points: 50
Originally Posted by firehawkmph View Post
Bude,
Mike Hawkins
Good advice Mike . The only other thing to add is after you true the rotor, use your angle die grinder with a fine scotchbrite pad, on the turned surface to get a non-directional finish.
Old 12-23-2009, 07:38 AM   #7
I used to take my drums off & have them turned by a local shop
Last SUV I dropped it off for a brake job & they wanted to replace all the drums
They aren't as thick any more, some shops won't (can't) turn them once they get past a certain point
Old 12-23-2009, 07:56 AM   #8
47_47's Avatar
Rewards Points: 50
Around here, you really don't turn rotors, you replace them. They rust and pit from all of the road salt. It's a shame after 3 years, you're doing pads and rotors and the pads still have over half the thickness.
Old 12-23-2009, 07:56 AM   #9
Mold!! Let's kill it!
Rewards Points: 2,012
I had brake chatter issues with a Ford car. I'd true up the rotors. First heat up, they'd chatter. True them up again. same thing. When they reached minimum thickness, I trashed them and put on Chinese made ones from Autozone. I thought this will just be another exercise in futility. Guess what!! Those Chinese rotors were on for years without a problem.....
Old 12-26-2009, 09:24 PM   #10
Get Powerslot rotors with Hawk pads you will be very pleased.
rodm1 is offline   Reply With Quote
Old 12-28-2009, 03:11 PM   #11
F-150 brakes are undersized to begin with. So they warp fast. I prefer the thermal quiet pads from wagner and the Brembo rotors available from tirerack.com, believe it or not! Bendix is made in China now too, so the quality just isn't there anymore. In my opinion, they are no better then the dura-won't-last crap you get at auto zone these days.
zackinma is offline   Reply With Quote
88' F150 heater core elscorcho Automotive Repairs 3 10-26-2008 09:43 PM
