New Muffler Fitting - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 05-19-2012, 01:40 PM   #1
New Muffler fitting
Hey, I just got a new muffler yesterday for my 05 GMC Canyon after straight piping it about 2 months ago but in order to get the new muffler to fit in I need to have a smaller piece of pipe in between where the old muffler was cut out.
I was planning on just taking the easy way out and getting a small piece of pipe to use as a sleeve to go over the 2 pipes and clamp it down but cannot find anything big enough anywhere locally.
I have a welder in the Barn that I bought on ebay a few weeks ago and have thought about welding the piece of pipe to the muffler then just lift it up under the truck and clamp it down on the 2 ends but im not 100% sure about the grounding clamp on the welder. If I was to just put the muffler and pipe on a wooden work bench I have would it be safe to just put the ground clamp on the other end of the mufffler or would I have to do something else with it?
Sorry for the long post and thanks for any help understanding.
bigjoe1986 is offline   Reply With Quote
Old 05-26-2012, 10:19 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 674
Ayuh,... So long as the ground clamp is attached to the same steel as yer weldin',...
Ya, it'll work just Fine...
Bondo is online now   Reply With Quote
Advice needed: Replace corroded fitting to well pipe? lightwolf Plumbing 1 11-30-2011 08:02 PM
Copper Y fitting and cabinet install brneilly Plumbing 4 06-30-2011 10:13 AM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 06:30 PM
Cracked PVC fitting in concrete DJupin Plumbing 6 07-29-2008 04:12 PM
