New Brakes For Dodge Ram 1500 4x4 - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-16-2011, 11:23 AM   #1
New Brakes for Dodge Ram 1500 4x4
Just replaced the brakes on my Ram and when I hit the highway the brake peddle started to vibrate severly. Returned to shop (I'm a desiel mechanic) and looked at brakes again and could find nothing wrong any suggestions at what might be causing vibration?
Track Dad is offline   Reply With Quote
Old 03-16-2011, 11:38 AM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
Warped rotor coming into contact with the brake pad?
Does your truck have ABS?
hyunelan2 is offline   Reply With Quote
Old 03-16-2011, 11:40 AM   #3
2005 Dodge Ram 4 x 4
Yes does have ABS I'll check the rotors again but didn't looked warped.
Old 03-16-2011, 11:46 AM   #4
hyunelan2's Avatar
Rewards Points: 692
With ABS, make sure you didn't knock a wheel speed sensor loose - that can throw the the ABS system into confusion.
Did you just replace the pads or pads & rotors?
Old 03-17-2011, 05:23 PM   #5
ukrkoz's Avatar
Rewards Points: 946
OK, brake pedal vibrates when pressed or simply vibrates at hwy speeds?
can't tell. what exactly is that you did? just straight brake pads replaced? rotors were not touched? rotors do not warp from pads change. and you can not tell if they are warped by looking at them anyway.
if you DID NOT have that issue before, and have it immediately AFTER brake pads were replaced, my 1st bet is one of the pads is not sitting right on the bracket. crooked. happens. next guess is, caliper is acting up. 3rd gues is - did you, actually, lubricate guides and pads seats with caliper grease?
ukrkoz is offline   Reply With Quote
Old 03-21-2011, 01:01 PM   #6
Turn the rotors!! It will go away and make sure you got all your shims in and the are not messed up. That will cause vibration..
MatthewTL is offline   Reply With Quote
Old 03-21-2011, 01:04 PM   #7
You will not see it but if you put it on a machine you might have to turn them 2xs
Old 03-27-2011, 08:37 PM   #8
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
Is your axle nut tight? On My GMC S-15, I had the same issue. Had the rotors turned, no warpage. But it wasn't a slip-off rotor, and the axle nut wasn't even finger tight (cotter pin was the only thing holding it on, apparently). I tightened it the proper amount (it was loose due to previous-owner-syndrome), and it went away.
Don't hit it with a 1" impact as high as it will go, but hand tighten so that it's snug.
I hate signatures.
Mort is offline   Reply With Quote
Wow 120,000 BTU in 1500 sq/ft zootjeff HVAC 5 01-03-2011 08:44 PM
Trane XE 1500 burnt wire and wiring questions parkham HVAC 10 01-25-2010 08:01 PM
Trailer Brakes NEED HELP plz Jeepster Automotive Repairs 4 09-13-2009 06:45 PM
Trailer brakes bucksone Automotive Repairs 1 09-01-2007 07:47 PM
Replacing Disc Brakes On 91 Toyota Corolla bobo Automotive Repairs 4 07-03-2007 06:31 AM
