Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-27-2013, 08:18 PM   #16
Need some heat
I used a wood chisel and hammer to remove those quick connects. Then i used hose clamps and fished the hoses in through the truck. I then used plumbing fittings to flare out to the 1 inch and a half fitting on the block. Between buying those hoses and the disconnect toll I save a lot of money. Did you feel the hoses to see if they were hot? I am glad to hear your truck is all old school. The computer control trucks get better mileage, but they never seem to stay running properly.
paintdrying is offline   Reply With Quote
Heat won't stop running, just installed new thermostat NorthSidePK HVAC 28 11-01-2012 11:05 AM
dual fuel heat pump - no heat without propane sweetfarm HVAC 3 10-11-2012 09:07 AM
VisionPRO Setup Functions & Heat Pump infoskr HVAC 31 03-18-2010 02:15 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
