Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-19-2008, 10:27 PM   #1
chaz-824
Unhappy
my toro 824 snowblower wont run..ys that??
i have a toro 824 snow blower and its pretty old. It hasn't been able to run for a couple of years now. I rebuilt the carb and it wasent getting a spark off the coil so i replaced that to. well now i go over to start it and it still wont start.. all i know is that im getting a spark and fule is getting to the piston. the only thing is that it wont start over ... what should i do ??
chaz824 is offline   Reply With Quote
Old 12-21-2008, 07:51 PM   #2
Safe, Most of the Time!!
brokenknee's Avatar
Pull the plug, if it is wet at all take a propane torch and heat it up to burn the gas off it. Try starting with starting fluid. If it runs then it is a fuel problem, if not it is electrical.
It is possible you flooded it while trying to start it.
I am assuming you put in fresh fuel when you rebuilt the carb.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
toro 824 2 stage snowblower wont stay running without starting fluid Milk duds e Automotive Repairs 6 01-01-2009 12:16 AM
jammed snowblower Dee_M General Discussion 11 11-28-2008 12:19 AM
Need help w/ Toro snowblower Rigby Tools 5 02-17-2008 09:49 AM
Toro SnowBlower 521 metallic sound mteach General Discussion 1 12-13-2007 01:27 PM
