-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   my toro 824 snowblower wont run..ys that?? (http://www.diychatroom.com/f46/my-toro-824-snowblower-wont-run-ys-34081/)
chaz824 12-19-2008 10:27 PM
i have a toro 824 snow blower and its pretty old. It hasn't been able to run for a couple of years now. I rebuilt the carb and it wasent getting a spark off the coil so i replaced that to. well now i go over to start it and it still wont start.. all i know is that im getting a spark and fule is getting to the piston. the only thing is that it wont start over ... what should i do ??
brokenknee 12-21-2008 07:51 PM
Pull the plug, if it is wet at all take a propane torch and heat it up to burn the gas off it. Try starting with starting fluid. If it runs then it is a fuel problem, if not it is electrical.
It is possible you flooded it while trying to start it.
I am assuming you put in fresh fuel when you rebuilt the carb.
