Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-17-2011, 09:11 AM   #1
jsmith48's Avatar
My fuel injector went out
My fuel injector is bad, my car will rev up high and barely move, has anyone done the procedure themselves?? I have little mechanical ability, is it a task that is going to be very indepth? My car is a 2007 honda accord
jsmith48 is offline   Reply With Quote
Old 08-17-2011, 10:06 AM   #2
STAFF
BigJim's Avatar
http://www.ehow.com/how_4509065_repl...da-accord.html
Maybe this will help a little.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
Old 08-17-2011, 11:30 AM   #3
ukrkoz's Avatar
though I really doubt one injector will cause high revs and total loss of power. more sounds like transmission problem. unless not one, but most of your injectors are dead, but then engine should simply stall.
ukrkoz is offline   Reply With Quote
Old 08-17-2011, 02:54 PM   #4
ukrkoz's Avatar
got to think about it - bad injectors will not allow car to rev. they are either flooding plugs, or not providing enough fuel, either way - engine won't rev or run.
Old 08-17-2011, 04:42 PM   #5
Experienced
Jackofall1's Avatar
The engine would not run or run roughly with bad injectors, if its reving, and you aren't moving while in gear, your tranny is in need of repair. I am sure there were warning signs along the way that you didn't recognize.
Don't drive it as it will only result in more damage, have it towed to a dearlership of tranny shop for inspection.
Mark
Old 08-17-2011, 06:28 PM   #6
Household Handyman
"My fuel injector is bad." Now I'm not a professional mechanic for a living, but I have worked on many cars in my friends shop to help him out. I have never seen a car with only "ONE" fuel injector, two (2) is the minimum I have seen in any car. Ex: The GM throttle body units. With the motor revving up, I doubt you have a fuel injector problem. Maybe an engine management problem with the ECU. This is a case where it would pay for a good diagnostic check-up.
Old 08-20-2011, 09:34 PM   #7
westgateblvd's Avatar
Talking about the transmission.. Check the fluid level of the transmission first. After you see the level on the dip stick.. Take a sniff of the fluid on the stick. If it smells burnt.. You might need to replace the fluid. My 37 Ford as a 350 Chevrolet engine with a 350 turbo hydro automatic transmission. When I first started the car I tried to get it in gear. I could rev the engine, but with not enough fluid it would not move.. If you still think it is a dirty injector.. Try adding a can of Seafoam.. Al
westgateblvd is offline   Reply With Quote
Old 08-24-2011, 09:44 PM   #8
Have you pulled the trouble codes from the ECU? If you haven't, take it to an advance/autozone. They will do it for free. Fix any you find first.
If you are thinking the injector is bad, get an ohm meter. Normally, healthy injectors will ohm out at between 11-14 ohms.
I have seen plenty of cars with a single injector go bad. Usually pintle type injectors are the most vulnerable. The E10,E15 type of fuel tends to play havoc with them.
That said, it doesn't sound like an injector to me either. As Urkoz stated, it will usually stumble, miss and have a lack of throttle response/power.
Marty1Mc is offline   Reply With Quote
paslode cf325 fuel cell adapters club22974 General Discussion 2 04-10-2011 12:18 PM
Fuel Cell vs batteries? Red Squirrel Electrical 9 05-13-2010 08:54 AM
Fuel savings from burner/nozzle reduction EfficientCanuck HVAC 13 03-01-2009 08:21 PM
Broken Burner Fix mikelbeck HVAC 2 01-16-2009 10:05 PM
Add electric heat so suppliment fuel oil? arichard21 HVAC 12 01-13-2008 11:23 AM
