-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   My Ford Freestyle is Dead (http://www.diychatroom.com/f46/my-ford-freestyle-dead-120686/)
Katigan 10-20-2011 01:54 PM
Hi!
This morning I was about to leave to do errands, and my car wouldn't start. When I turn the key, nothing happens: no sound, no movement. The headlights work, the lights inside the car are on, even the alarm to let you know you left your headlights on works. The phone charger still works and the only light on the dash is the blinking "theft" light. We tried putting more gas in, we tried jumping it, but nothing seems to be working. We haven't driven the car in about a week.
Does this sound like a dead battery? Or something more?
Thanks so much for any advice you might have!
cjm94 10-20-2011 02:15 PM
If the theft light is flashing fast you have a problem with your key. Either your key is bad or the transponder in the ignition switch may be bad. Try another key that is the most common problem.
Katigan 10-20-2011 02:23 PM
We do have two keys for this car and neither work. In the past it's had some rough, prolonged startups. Could it be the starter?
cjm94 10-20-2011 02:41 PM
Very possible but if the theft light is flashing fast when you turn the key the security system disables the starter. The light should come on for a second or two with the key on and then go out.
polarzak 10-20-2011 05:18 PM
I know you have a Ford, however my daughter's boyfriend had exactly the same problem/symptoms with his GM. and it WAS a dead starter. Perhaps it is the same with your Ford.
Doc Holliday 10-20-2011 07:38 PM
Could also be the negative cable, loose connection, to the starter. That happened on my Ford truck and I as well had interior lights but she acted dead.
I came back after work, riding in the company truck all day, and got in mine after it sitting all day and nothing.
Found the wire, jiggled it a bit and full power, cranked right over.
Might give a look into that.
cjm94 10-20-2011 08:20 PM
If the light is blinking this needs to be checked out. A bad starter or lose cable won't cause the theft light. This is caused by the anti theft module not reading the key correctly.
Doc Holliday 10-20-2011 09:41 PM
well excuuuuuuUUUUUUUUUUUUuuuuuuuuuusee me. :thumbup:
cjm94 10-20-2011 09:56 PM
Didn't mean to offend anyone. I am a tech at a ford dealer and see this concern. :)
Doc Holliday 10-20-2011 10:30 PM
You didn't, I'm just being a clown.
Bud Cline 10-20-2011 10:32 PM
I'd start with cleaning the battery terminals and cable connectors.:)
rusty baker 10-20-2011 10:55 PM
I'd just burn it and collect the insurance. :laughing:
Doc Holliday 10-20-2011 11:06 PM
Know anything about '98 F-150's? I've heard that the catalytic converter on the six cylinders tend to become blocked.
I have one, 4.2, and it doesn't have the power, especially from take off from a red light, she once did. Now at 165k miles. On the freeway, no problems.
Like it's having trouble breathing or exhaling if you will.
Thanks.
cjm94 10-20-2011 11:17 PM
Yes I have seen a few of them plugged. I would also check the mass air flow sensor on the air cleaner they get dirty and reduce power. An easy check for the cat is to loosen the exhaust before it and take a drive. Will sound like a hot rod too;)
Bud Cline 10-21-2011 08:21 AM
...or maybe it's a coil on one (or more) of the spark plug wires.:)
