My Buick Has To Much Wiggle IN The Front - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-14-2013, 07:40 PM   #1
Smile
My Buick Has To Much Wiggle IN the front
I just replaced the cv axle on my car but now I have a really bad vibration in the front. maybe I need new tires what do you think any feed back would be welcome. Thanks guys
PartsGal is offline   Reply With Quote
Old 07-14-2013, 08:11 PM   #2
Rewards Points: 254
Did it shake before? If not make sure everything is tight.
cjm94 is offline   Reply With Quote
Old 07-14-2013, 08:40 PM   #3
Rewards Points: 13,300
Could be any number of things.
Bad ball joint, bad CV, tie rod, failing side wall on a tie ECT. No one here is going to be able to trouble shoot this for sure over the net.
Old 07-15-2013, 11:29 PM   #4
r0ckstarr's Avatar
Rewards Points: 1,998
If it didn't vibrate before you replaced the CV axle, then the vibration is from something you did while replacing the CV axle. Go back over all of your work and verify that everything is correct and tight. This includes the lugnuts to the tire you took off.
r0ckstarr is online now   Reply With Quote
Replacing a concrete front door approach with a boardwalk? bigdaddydavy Building & Construction 10 05-31-2012 10:08 PM
Help with paint colour for the garage and front door syndicate1 Interior Decorating 7 07-25-2010 07:08 PM
Drying time and painting a front door gramps416 Painting 1 05-17-2010 12:01 PM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 11:46 PM
Adding new Front Porch, need opinions MeraleeCrowl Remodeling 1 11-05-2008 01:47 PM
