-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   My Buick Has To Much Wiggle IN the front (http://www.diychatroom.com/f46/my-buick-has-much-wiggle-front-183627/)
PartsGal 07-14-2013 06:40 PM
I just replaced the cv axle on my car but now I have a really bad vibration in the front. maybe I need new tires what do you think any feed back would be welcome. Thanks guys:)
cjm94 07-14-2013 07:11 PM
Did it shake before? If not make sure everything is tight.
joecaption 07-14-2013 07:40 PM
Could be any number of things.
Bad ball joint, bad CV, tie rod, failing side wall on a tie ECT. No one here is going to be able to trouble shoot this for sure over the net.
r0ckstarr 07-15-2013 10:29 PM
If it didn't vibrate before you replaced the CV axle, then the vibration is from something you did while replacing the CV axle. Go back over all of your work and verify that everything is correct and tight. This includes the lugnuts to the tire you took off.
