My 2000 Saturn LS1 Shakes When I Go To Turn It On! - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-26-2011, 02:44 PM   #1
Unhappy
My 2000 Saturn LS1 shakes when I go to turn it on!
HELP! I just went to start my car, put the key in the ignition and it shock really bad, made a whinning noise, and the service engine light came on.
I turned it off and tried again with the same results.
Can anyone please tell me what may be the problem? I drove this yesterday with not problem.
Thank you.
Jesse1 is offline   Reply With Quote
Old 02-26-2011, 05:00 PM   #2
ukrkoz's Avatar
Rewards Points: 970
and it is today, unfortunately.
1st guess is, it's misfiring or timing is bad.
i don't know if you have distributor or coil packs. if you have distributor, then it might be there. if you have coil packs, then likely something in timing/ignition setup went wrong.
is it just shaking and stalling, or backfiring? if it's backfiring, timing belt might have slipped, if you have belt, or ECU went south. or one of the vital sensors.
go to any parts store, rent OBD2 scanner, plug it in and read codes. I said - GO, i did not say drive. buddy, spare car, public transportation, bicycle, jog...
ukrkoz is offline   Reply With Quote
The Following User Says Thank You to ukrkoz For This Useful Post:
tpolk (03-05-2011)
Old 03-05-2011, 04:59 PM   #3
I would make sure you engine mounts( probably 3 or 4) arn't cracked.
Jwilliams240sx is offline   Reply With Quote
The Following User Says Thank You to Jwilliams240sx For This Useful Post:
Tom Struble (03-06-2011)
Old 03-05-2011, 06:47 PM   #4
Bigplanz's Avatar
Rewards Points: 990
Have the codes pulled. It could be several things, but the code will point you in the right direction.
Bigplanz is offline   Reply With Quote
Old 03-07-2011, 03:47 PM   #5
Well if its 4 cyl it will have a timing chain and I have fixed them before with what you described they are also very expensive. But I agree you need to have the codes pulled Auto Zone will pull them for free then post them also when the car is running go to the back of the exhaust and listen for a poofing noise and see if the engine is shaking.. not rocking this will let you know that the car is mis firing and then you should not drive it unless you are going to get it repair you could melt your catalytic converter. When you do get the codes pls post them and we will see what it takes to fix it..
Matthew
MatthewTL is offline   Reply With Quote
Old 03-07-2011, 07:57 PM   #6
Rewards Points: 87
I had that once with an older car, had carbon build up in the cylinders which just got hot enough that they'd fire off a couple extra rounds after the car shut off...
phantasm72 is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Using Felt with Cedar Shakes freddmc Roofing/Siding 32 10-08-2011 11:26 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
My saturn shakes really bad while idling?? timthetoolman Automotive Repairs 14 12-04-2009 09:38 PM
2000 Saturn wiper motor problem ashukoff Automotive Repairs 1 10-02-2008 11:38 AM
