Motorhome - Oxidation Build Up - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 05-23-2010, 09:47 AM   #1
I just bought a used motorhome (1985 Ford Elderado) which has a lot of oxidation build up on the exterior - does anyone know how to remove it? or a compound that will remove it? I believe the exterior is fiberglass. I don't know if just a buffer would work or if I need something as an abrasive?
blondie11.11 is offline   Reply With Quote
Old 06-15-2010, 09:43 AM   #2
cowboy dan's Avatar
magic eraser. you are talking about rust on fiberglass running boards and such? be carfull though, it will remove your paint if you aren't.
cowboy dan is offline   Reply With Quote
Old 06-19-2010, 09:36 PM   #3
Rewards Points: 410
I would probably use Mequiars paint cleaner.
You can try there call center for more detailed advice , I've called them before, very helpful.
CALL
Our trained appearance care Specialists are here to take your calls six days a week.
1-800-347-5700
Hours: M-F 6 a.m. to 5 p.m. (Pacific)
Saturday 7 a.m. to 3 p.m. (Pacific)
High Gear is offline   Reply With Quote
Tags
build-up , fiberglass , motorhome , oxidization , oxidized
time to build simple addition bmt1970 Building & Construction 9 03-05-2010 02:06 PM
Plans for how to build sash-pulley window jambs, etc.? DyerWolf Carpentry 1 11-28-2009 09:26 PM
Build or buy a shed and costs? Piedmont Building & Construction 7 05-19-2009 07:13 PM
1990 Bounder Motorhome 3 prong outlets actally have no ground connected!! Help! Holering Electrical 5 03-30-2009 12:59 PM
To Build or Not To Build scoby1978 General DIY Discussions 6 05-27-2007 04:39 PM
