Motor Question On Boat - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-12-2012, 10:49 AM   #1
Rewards Points: 109
Motor Question on Boat
After my boat sits a few days or longer, When i go to start it ,it will not start. Its not getting gas to the Carb.(Took line off at carb) But when i spray it with gum out a few times it will start and starts everytime their after.If it sits a again it will not start ,It has a elecrric fuel pump. Could this be the fuel pump? If is ,why does it work after getting started with gum out? Thanks
lemley98 is offline   Reply With Quote
Old 04-12-2012, 11:59 AM   #2
Rewards Points: 12,794
Might help to give more info on what type motor you have.
Sounds like the cheak valve is leaking fuel back into the tank.
What I did on mine was install a squeze ball in the line, it alowed me to prime the carberator and the check ball in the bulb kept it from leaking back.
May not be the "right way" but it worked for me and it was cheap.
Always double clamp fuel lines on a boat, if one fails the other one will keep it on.
Use all stainless hose clamps, not the ones with a steel screw or band.
Old 04-12-2012, 02:14 PM   #3
Rewards Points: 109
Thanks for the reply. Thats interesting. can i put the squeeze ball before the Canister fuel filter? It will be the Tank then squeeze ball then filter, pump then Carb. Also can i possible put another check valve right before the fuel filter?
Old 04-12-2012, 02:43 PM   #4
Rewards Points: 109
Almost forgot! Its a 19 ft Marada with a 4.3 Litre engine (not Fuel Injected) Inboard/outboard
Old 04-12-2012, 03:36 PM   #5
47_47's Avatar
Rewards Points: 44
Electric pumps push fluid. Where if the pump? Is it in or near the tank or by the engine?
47_47 is online now   Reply With Quote
Old 04-12-2012, 03:39 PM   #6
Rewards Points: 109
closer to the engine,you have the tank with hose going to the canister filter then the pump to the carb.
Old 04-12-2012, 09:09 PM   #7
Rewards Points: 109
Any thoughts? A new fuel pump is a little over $200. Does anybody think its the fuel pump? check valve? or else? Hate to spend that kind of cash if not sure. thanks
Old 04-13-2012, 01:10 PM   #8
Rewards Points: 109
Somebody? Thanks
Old 04-13-2012, 02:02 PM   #9
Without being there to see it my gut feeling is to put it before the fuel filter, the reason is when you change the filter it would give you a way to fill it with fuel and prime the line.
Old 04-13-2012, 09:00 PM   #10
Rewards Points: 252
I wouldn't change the fuel pump unless I was sure it's the problem. I would check the pressure in the line at the carb first. Get a pressure gauge and put it inline, turn the switch to the start position, then check if you have pressure. If you don't then work backwards. It seems to me that your pump is probably working, but losing prime. Otherwise, it wouldn't run after you got the motor started.
I think the above suggestion is good, and I would try that as well.
Marty1Mc is offline   Reply With Quote
Old 04-13-2012, 09:49 PM   #11
Rewards Points: 109
OK Thanks
Old 04-15-2012, 12:08 PM   #12
Master General ReEngineer
Bondo's Avatar
Rewards Points: 334
Originally Posted by lemley98 View Post
OK Thanks
Ayuh,... Is this a Mercruiser 4.3l,..?? 4bbl. carb,..??
If so, it's the carb leakin' off, not yer fuel pump...
Bondo is online now   Reply With Quote
Old 04-23-2012, 04:54 PM   #13
Rewards Points: 150
How old is engine, how old are fuel line hoses, does the pump ball hold pressure have you changed fuel filter? Also where are you located-ethanol?
Ethanol eats fuel lines, gums carbs as well as any number of other problems.
Also what type fuel tank(permanent/portable)?
CaptRandy is offline   Reply With Quote
dc/ac power inverter on a boat bernie963 Electrical 4 08-16-2011 12:28 PM
How to install AC power in a boat Steeler99 Electrical 4 02-18-2011 06:52 PM
Boat Dock and encapsulated float bekind42 Building & Construction 4 08-07-2009 12:59 PM
Flooring for a boat house buddy333 Flooring 2 11-01-2008 10:46 PM
Shower for Boat house ckornbau Plumbing 6 01-08-2007 11:47 AM
