Moisture In My Front Turn Signals? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-07-2007, 09:08 AM   #1
moisture in my front turn signals?
i had recently noticed some moisture in one of my front turn signals. i didnt think anything of it untill a couple months later it stopped working. when i went to replace it, i noticed the whole socket was corroded and i had to break the light and rip the bottom to pieces with pliers just to get it out of the socket. once i got it out i noticed a type of "glass" had formed inside the bulb connector. the corrosion was so bad that even after i got the bulb out, the fitting would not fit back into the headlamp because corrosion had widened the fitting. i am having this problem on a GMC denali 2000, and was wondering waht i should do to fix it?
starnz is offline   Reply With Quote
Old 07-07-2007, 11:53 AM   #2
Deplorable Electrician
MechanicalDVR's Avatar
Rewards Points: 81
Replace the light and socket, there was most likely a crack in the fixture that was not allowing it to seal water tight
MechanicalDVR is offline   Reply With Quote
Old 07-07-2007, 10:36 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
You could clean up the socket, but I agree with Mech, you really should replace the socket
slickshift is offline   Reply With Quote
Old 12-24-2007, 10:18 AM   #4
I had a mustang do the same thing, I drilled a small (1/8) hole in the very bottom to let the moister out.
saltydevildog is offline   Reply With Quote
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 04:22 PM
To Moisture Barrier or Not to Moisture Barrier? cordon Flooring 7 05-22-2007 10:48 PM
moisture barrier - help! jediracer Carpentry 12 10-03-2006 07:32 PM
Faucet won't turn off etiger Plumbing 1 08-31-2005 03:46 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
