Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-11-2010, 03:24 PM   #1
Making Throttle body spacer
Hi all, does anyone know how to make a throttle body spacer?? is there any specific details instead of boring a hole into a 25mm aluminium metal?? thanks before...
disaresta is offline   Reply With Quote
Old 09-13-2010, 12:43 PM   #2
Household Handyman
Let me say this first: I have built many car motors, both for regular daily driver use and for dirt track racing use. I am also a machinist/maintenance tech with 38 years under my belt. Unless you have the proper machine tools, the proper aluminum material, and the knowledge of how to use these tools to do this--Don't! Throttle body spacers are not just a piece of cardboard put there to provide more distance for creating air turbulence. Throttle body spacers are complicated. Look at a commercially made one, it will have a tapered bore and the inside of the bore will appear to be polished. Do you have equipment to do this? Methinks not. Go buy one if you feel the need for one. Better yet, why would you want one? David
Thinking about making concrete pavers - a few questions Luis C. Building & Construction 16 06-10-2011 06:45 PM
QEP Bullseye spacer mod for running bond subway tile diy888 Remodeling 4 04-26-2009 07:29 AM
Shower body jets Moparman Plumbing 5 05-23-2008 08:49 PM
Help ! May have to replace older model Streamway mobile home tub faucet valve body !! Musicloverz Plumbing 2 01-26-2008 08:04 PM
Toilette flange spacer klemmy Plumbing 6 04-17-2007 02:50 PM
