Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-01-2009, 09:50 PM   #1
losing power
I just replaced my head gaskets, valve cover gaskets, exhaust intake and manifold gaskets, thermostat, thermostat gasket, water pump, water pump gasket, spark plugs, spark plug wires. I found a few leaky hoses and replaced them. Now I've lost a lot of power and can't get her past 35. She also likes to stall at stop signs and hills are a no win situation. She is an old *****, 87 dodge dakota, but right now it's all I have and I gotta keep her running. Any ideas?
=Eric
erickelly is offline   Reply With Quote
Old 09-01-2009, 10:40 PM   #2
Oldguy
Rehabber's Avatar
losing power
One common problem after blowing a head gasket, is a clogged catalytic converter. check the exhaust backpressure.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 09-03-2009, 07:27 AM   #3
losing power
BACK to square 1.
Start with your wires again and confirm firing order, just in case. Check vacuum hoses first one by one look for and listen for a hiss, then check locations...
Then double check your torque on head and manifold gasket and intake as well.
I'm guessing you're sucking air somewhere
Chemist1961 is offline   Reply With Quote
Old 09-06-2009, 08:51 AM   #4
Household Handyman
losing power
erickelly: I agree that it sounds as if you have created a vacuum leak somewhere. Invest in a cheap set of Doctor's type stethoscope, take the cup off the end of it, and use it to investigate for vacuum leaks. Listen at each hose connection, you may be surprised to find leaks you never suspected. If you can't find a stethoscope, you can use a length of plastic/rubber tubing, just hold one end to your ear and place the other on the vacuum hose ends. In my area, I don't know about yours, most muffler shops will do a quick catalytic converter test if they are not real busy and feel that they may get your business. Most of them use an infra-red thermometer and take readings before and after the cat. If the temp difference is too high before and after then it's a sure sign the cat is blocked. Simple enough if you own an infra-red thermometer, I think they look for a temp difference of 150 degrees or more. Good Luck, David
How do I get power to a new ceiling fan? sestivers Electrical 12 04-25-2011 03:11 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Losing power, length? size? Kellxr7 Home Theater 5 12-05-2007 12:19 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
