Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 05-11-2007, 10:20 AM   #1
Location of turn signal flasher?
I have a 2001 Tundra and I'm trying to replace the turn signal flasher but cannot locate where it is.
I looked around the fuse panel located on the lower left side of the dash. I also looked inside the fuse box located inside the engine compartment.
I would certainly appreciate any help or direction someone could provide. I hope someone has intimate knowledge of the Tundra's.
Thank you in advance.
Bigman610 is offline   Reply With Quote
Old 05-11-2007, 11:33 AM   #2
I have gas!
Clutchcargo's Avatar
I don't have a Tundra but from the autozone website:
On your 2001 Toyota Truck Tundra 2WD 3.4L EFI DOHC , the Flasher is located:
Front seating area, driver side, behind dash, corner, mounted below junction block
HTH
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 05-11-2007, 12:47 PM   #3
Thank you
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 04:22 PM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 03:17 AM
Faucet won't turn off etiger Plumbing 1 08-31-2005 03:46 AM
