-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   Location of turn signal flasher? (http://www.diychatroom.com/f46/location-turn-signal-flasher-8384/)
Bigman610 05-11-2007 09:20 AM
I have a 2001 Tundra and I'm trying to replace the turn signal flasher but cannot locate where it is.
I looked around the fuse panel located on the lower left side of the dash. I also looked inside the fuse box located inside the engine compartment.
I would certainly appreciate any help or direction someone could provide. I hope someone has intimate knowledge of the Tundra's.
Thank you in advance.
Clutchcargo 05-11-2007 10:33 AM
63 Attachment(s)
I don't have a Tundra but from the autozone website:
On your 2001 Toyota Truck Tundra 2WD 3.4L EFI DOHC , the Flasher is located:
Front seating area, driver side, behind dash, corner, mounted below junction block
HTH
Bigman610 05-11-2007 11:47 AM
Thank you
