Late 80's Toro 826--Weak Throwing Power - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-20-2008, 04:59 PM   #1
I have a late 80's Toro 826 snowblower and its throwing capability is decreasing. Does anyone know if there is an adjustment that can be made, or if there is a clutch that could be going bad? The snowblower still runs good, just doesn't move as much snow as it did before. Any advise would be appreciated.
toro826 is offline   Reply With Quote
Old 12-20-2008, 09:30 PM   #2
Rewards Points: 2,906
Same thing happened on my Canadiana 5 hp snow blower. It turned out to be that the auger belt gradually stretched, thereby resulting in slippage and decreased throwing distance.
Between the motor and the auger scoop, there was a cover on my snow blower. Removing it provided access to two belts. One belt drove a large pully that propelled the machine forward and backward. The other belt drove a large pulley that powered the first and second stage augers.
You should be able to see a belt tightening mechanism for that second belt, but the best fix is to buy a new belt.
On my machine, you could replace that second belt without doing any more than removing that cover and loosening the belt tightener. It was an easy job.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 12-23-2008, 07:11 PM   #3
Yea, buy a belt slightly smaller than the one you remove. Make sure all tensioners are tight.
I did something similar last year. Still throwing excellent!
Tommy2 is offline   Reply With Quote
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 04:16 PM
Power Save Device capt2 Electrical 52 02-24-2010 06:42 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
