Kill Me Now. - Automotive Repairs - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-10-2013, 12:40 PM   #16
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
Before rubbing compound, try using a claybar instead. Worked wonders when I traded paint on my black truck with a blue tahoe. Takes a little less effort than compound too. After you get the most of it off, then I'd do a low-speed with some compound on a random orbital, followed with a high-speed polish.
If compounds won't do anything, wetsanding is not that complicated either.
hyunelan2 is offline   Reply With Quote
The Following User Says Thank You to hyunelan2 For This Useful Post:
r0ckstarr (06-10-2013)
Old 06-10-2013, 04:59 PM   #17
Challenge Everything!
Deja-vue's Avatar
Rewards Points: 157
With all due Respect: Get it to a Body Shop already before you make it worse. It takes a lot of practice and the right Tools to straighten this out.
Do you have a Paint-booth? Hydraulic pullers?
This is not a simple Dent-removal, trust me.
And please, don't start drilling holes.
Deja-vue is offline   Reply With Quote
The Following User Says Thank You to Deja-vue For This Useful Post:
BirdSlapper (06-13-2013)
Old 06-10-2013, 08:01 PM   #18
I'm Your Huckleberry
Rewards Points: 2,270
Just had the rear tire patched at Discount Tire, took a few more pics. I tried using their tire mallet to pop some of the dent out but no luck. It felt as if I had a heavier mallet and more room to swing it it would pop out or some of it at least.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 06-10-2013, 10:11 PM   #19
Originally Posted by Doc Holliday View Post
rails a concrete pole in the parking lot. .
DOC!!!
How ?? Why ?? Was the parking lot empty...
creeper is offline   Reply With Quote
Old 06-10-2013, 10:21 PM   #20
Originally Posted by creeper View Post
DOC!!!
I'll get a pic of the pole and parking lot, just give me 'till the weekend's end. The pole is short and fat and yellow and positioned right where the driveway to the parking lot meets the parking lot. I was making a right into the parking lot on the uphill driveway and decided to make a right u-turn to get to a parking spot right there. Going up hill and the pole being so short I didn't even see it.
Sucks, but lucky I got that truck for about half of it's worth. I can afford to spend it's other halve's value in repairs and a paint job/body overhaul was in the plans already. Just might take a while getting it all done.
Thanks.
The Following User Says Thank You to Doc Holliday For This Useful Post:
creeper (06-10-2013)
Old 06-10-2013, 10:21 PM   #21
r0ckstarr's Avatar
Rewards Points: 1,998
Take a toilet plunger. Rub some vaseline around the rim of it. Put it right in the center here (see attachment). Push down and pull out.
This type works the best.
The dent below the body line will take a little more work (still not too bad).
The dent on the wheel arch will be the toughest one to get right, but it's possible.
r0ckstarr is online now   Reply With Quote
Old 06-10-2013, 10:24 PM   #22
That's actually the main part I'm disgusted with. Thanks, I'll try it, just got to get a plunger first and some time.
What about the dry ice thing? I've seen a few Youtube videos of it working.
Thanks.
Old 06-10-2013, 10:33 PM   #23
r0ckstarr's Avatar
Never tried the dry ice tricks. I'm more used to cutting out bad panels and welding in new metal.
http://www.flickr.com/photos/amdn/se...7619185593260/
...of course, this would require a repaint for sure.
Old 06-10-2013, 10:41 PM   #24
that is awesome work! I had no idea you were so talented.
I'm thinking I may find a bed for it and just have the entire truck painted. There's a truck wrecker yard called Bronco's Truck Salvage up north that has a lot of dead trucks. I've gotten a rear complete windshield (manual sliding middle) for $125.00 and the spare tire winch for $35.00. I'm hoping he'll give me a good deal. Mine might not be worth the headache and cost to repair.
Thanks.
Old 06-10-2013, 10:44 PM   #25
r0ckstarr's Avatar
Maybe you can swap beds with him for a discount.
Old 06-10-2013, 11:16 PM   #26
ukrkoz's Avatar
Rewards Points: 938
https://www.google.com/#q=suction+de...w=1920&bih=974
Likely not work on a crease though. You can use hammer dent puller, or weld rods and pull, or use good resin to bond rods and pull.
My neighbor does this for around $500, paint job included.
ukrkoz is offline   Reply With Quote
Old 06-10-2013, 11:19 PM   #27
ukrkoz's Avatar
Rewards Points: 938
Old 06-10-2013, 11:44 PM   #28
r0ckstarr's Avatar
Spitznagel.
Old 06-11-2013, 07:39 AM   #29
Remodeler
Rewards Points: 316
Most shops are going to want to change the box side. With multiple body lines damaged it would take a lot of time to pull it all out and get it to look right. Factory panels are pricey and most aftermarket panels offer thin material and more work to make them fit, they are cheaper for a reason.
If you go with a replacement box anything from a 99-13 will fit right on it. The 11-13's have a slightly different rounded flare around the wheel well where on the older box the flare is flattened. It is not terribly noticeable, but otherwise all the body lines and bolts line up perfectly. Painting a box is not going to be inexpensive either.
On an older box carefully check for rusted bed cross members, they rust out bad. I don't really see that many super duties badly rusted over the wheel wells but most of them have rusted cross members under the bed. Hopefully TX has been more friendly to them than Iowa is.
iamrfixit is offline   Reply With Quote
Old 06-11-2013, 08:05 AM   #30
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,954
+1 to fixing it yourself.
It won't be perfect and new but you can get most of it out from the backside and clay/compound to get the paint off.
Will Frost Kill Rust ? SPS-1 Landscaping & Lawn Care 3 09-29-2012 06:24 PM
To kill or not to kill no1hustler Landscaping & Lawn Care 4 08-22-2010 11:17 PM
Grubs Too Big To Kill AllanJ Landscaping & Lawn Care 6 05-24-2010 10:06 AM
How to kill weird fungus in mulched flower bed. Leah Frances Landscaping & Lawn Care 4 05-23-2009 01:21 PM
Kill Everything in backyard dankreboot Landscaping & Lawn Care 16 05-01-2009 06:54 AM
