Jacking A Ram Truck - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-27-2008, 09:12 PM   #1
Jacking a Ram truck
Need to jack up a 2004 4wd Dodge Ram truck so I can rotate the tires, so each side needs to be jacked. I have 2 hydraulic floor jacks and plenty of stands but not sure where to place the jacks. OEM jack is different, so don't think those locations will work with a floor jack.
Thanks.
Oldhickory is offline   Reply With Quote
Old 02-27-2008, 09:30 PM   #2
electrical contractor
Rewards Points: 150
Jack it up front and rear by placing jacks under differential center sections. Make sure your jacks can lift the weight, and support it with the stands placed under the axles, before you take the tires off.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 02-27-2008, 09:35 PM   #3
So...lift all 4 wheels and place stands...not one side at a time?
Old 02-28-2008, 06:29 AM   #4
Rewards Points: 150
thats the way I do it on my work truck and my personal truck. Most floor jacks do not have enough lift to lift from the side, the jack runs out before the tires clear the ground.
Jimmy
Old 02-28-2008, 11:08 AM   #5
Oldguy
Rehabber's Avatar
LIft all 4 wheels and cross rotate your tires on a 4 wheel drive vehicle. Don't believe me? Check your tire manufacturers recommendations. Prefered rotation will be an X on 4WD vehidles.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 02-28-2008, 08:21 PM   #6
NothingsLevel's Avatar
Before you lift the truck, break the lugs loose.
Floor jack under the rear pumpkin, get the tires off the ground, the jackstands under the axle (between the spring and the brake disc).
Fronts:
If it's a 1/2 ton, put the floor jack at the lift point on the framerail on one side, get the wheel off the ground, then a jackstand just aft of the jack. Repeat on the other side.
If it's a 3/4 or 1-ton, floor jack under the front pumpkin and do it just like the rear, just watch the balance because that differential is offset from center.
On your truck, unless it's different from Dakotas & Durangos of the same vintage, your rotation pattern should be: Fronts go to the back on the same side, rears cross when they go up to the front. LF to LR, RF to RR, RR to LF, LR to RF.
If you do a 5-wheel rotation...I forget which wat that one goes. It's in your manual though.
NothingsLevel is offline   Reply With Quote
Old 02-29-2008, 04:59 PM   #7
Oldguy
Rehabber's Avatar
Nothingslevel, the pattern you state is for a front wheel drive vehicle. The general rule is: cross to drive wheels.
Old 02-29-2008, 08:22 PM   #8
The manuals for both of my Dodge Dakotas disagree with you.
Old 03-03-2008, 01:11 AM   #9
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
Typically, on a 4wd you want all 5 tires in rotation. The X rotation is ideal if, in fact, you do put it in 4wd. How many people you know with grocery-getter mall crawlers? About 97% of the ones on the road don't shift into 4wd, and these vehicle would just get into more trouble if they did. Use your manual and make sure you check the tire pressure as both axles can be different and the PSI on the tires isn't what your vehicle recommends. Also, the pressure is lower when the tires are cold, so run it before you check. You may want to get the alignment checked and grease all your zerks. Might as well check your brakes while you got the tires off.
My floor jack will lift both pumpkins off the ground just fine. Now if your Ram has IFS (independent front suspension) put the floor jack under the middle skidplate (if it is a skidplate), or under the A-arms. I'd put jackstands under it just in case your floor jack craps out.
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 03-03-2008, 06:02 AM   #10
True, but unfortunately manufacturers are cutting costs by including a basic steel rim on the spare tire, instead of a matching rim. Which turns a 5-wheel rotation into a trip to the tire shop to remount and rebalance one tire. At which point you may as well have them rotate the tires while the vehicle's up on the lift.[/QUOTE]
Old 03-06-2008, 12:12 PM   #11
Fixer-'til-broker
Rewards Points: 262
Oh man - Good point! Most tire shops will include FREE rotation with tire puchase. If you have Discount Tire Co. in your area go there to buy tires - they will take care of you. I think Pep Boys might do the same.
I have custom MT Alcoa rims with an OEM spare. The spare stays in the Jeep during rotation. It's worn down enough to fit in the spare location aired down. Of course, my tires are oversized! I'll have to get an external rack when I go up to 36" tires.
Load Capacity of driveway - Will a dump truck crack it? Deavis Building & Construction 17 03-29-2015 08:43 AM
Jacking main beam/floor joists gshock Building & Construction 1 05-30-2007 08:17 AM
Need Advice (power Inverters for Ice Cream Truck) garagemaxx Electrical 4 05-15-2007 06:53 PM
Sidewalk Meets Concrete Truck Question craigNeasttx Building & Construction 5 03-24-2005 11:40 PM
