Originally Posted by johnd393
You know what a free spinning engine with no, or very little, compression sounds like from the sound, don't you?
Well, yes....it does have a sort of sound thing going on
But it really doesn't mean anything...it could be other things also
It's a suspicion, it's not conclusive by any means
Its certainly not enough to consider it a compression problem w/o an actual test
You need to do the test and find out if it's actually a compression problem
In reality, as far as we know at this point, you may have plenty of compression
You also need to do a timing test while it's running
I know you looked at it, but that doesn't tell us if the timing is actually wacked when it's running
