Installing Trailer Submersible Tail Lights - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-02-2011, 04:33 PM   #1
Installing trailer submersible tail lights
I am trying to break lights on the jetski trailer and have been having trouble with it. I have no instructions. The lights are called submerser-a-lite. My first try had all lights flashing, my second try had no breaklights but had turning lights on, my third attempt had light indicating the opposite way. There are 2 pair set of lights and each have 3 point wiring system on each light. What am I doing wrong?? Any helpers??
Baldhill2007 is offline   Reply With Quote
Old 01-02-2011, 05:07 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 992
Ayuh,... Of those 3 wires,...
1 is Hot for running lights,...
1 is Hot for brake lights,..
And,..
1 is the Ground...
How, Exactly, have you hooked 'em up to the tow unit,..??
A BFHammer works quite well...
Bondo is online now   Reply With Quote
Old 01-02-2011, 05:55 PM   #3
And,..
1 is the Ground...
Thanks Bondo, there are 4 wires on the left side which are red, brown, white and yellow. The other white one runs from the orange to the red light within the same unit.
One the right, I have white, red, brown and green. Another white one joining the other light within same unit like in the other one.
How then do I go about connecting them?
Thanks for all your help
Old 01-02-2011, 05:55 PM   #4
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Typical set-up is
Right Turn/ Brake Green
Left Turn/Brake Yellow
Ground White
Tail / Marker Brown
do your trailer lights have reverse lights? if so that should be the red
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 01-02-2011, 06:20 PM   #5
Originally Posted by Mr Chips
Right Turn Green
Left Turn Yellow
Ground White
Tail / Marker Brown
Okay here are the visuals of the connections. Which colour goes where? The top pic is the right one whilst the second is the left. I have tried to connect but still getting only the red light flashing and not the orange one. What should I do now. Thanks Mr. Chips
Old 01-02-2011, 06:30 PM   #6
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
can you post a pict of the front?
Old 01-02-2011, 06:33 PM   #7
Here it is, thanks mate
Old 01-02-2011, 07:02 PM   #8
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Ok, that's the difference, those were made in australia, and differ from US standards. The red lens is brake light, amber lense is turn signal.
so my guess is the red wire would be brake light
Old 01-02-2011, 07:35 PM   #9
Thanks mate and will got all almost done.
Old 01-07-2011, 04:40 PM   #10
Household Handyman
Rewards Points: 1,408
Top photo: Green is the turn signal wire (should be right turn), brown should be running light, red is brake light, the white going with green is ground and the white just jumps from one side to the other. Bottom photo: The only difference is the yellow will be the left turn signal.
Installing Pot Lights - 12AWG and 14/2 wire ... help! njchan Electrical 4 04-10-2008 06:50 PM
Installing pot lights billybarty Electrical 19 03-18-2008 06:58 PM
Installing can lights in a drop ceiling..... rwk0930 Remodeling 1 02-19-2008 12:59 PM
Installing Recessed Lights IdahoBob Electrical 6 08-23-2007 10:03 PM
installing lights in shower stall mcvane Electrical 2 03-30-2007 05:34 AM
