Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 05-06-2012, 09:41 PM   #1
Question
i have a 99 ford ranger.. need help
Ok. I had already put a new thermostat in it.. i know that it is over heating. But the thermoatat ir reading normal. What do i need to do???
lilwndrs21 is offline   Reply With Quote
Old 05-06-2012, 10:24 PM   #2
Metal Roofing
First you need to go to HD and buy a Tape, hammer, compressor and some drywall mud. Put that truck on a lift cover it in the mud, make sure you get a nice even coat of mud. Check it with your tape. Use the hammer to break the windows and over inflate those tires with the compressor. That should do it
maybe read this:
http://www.fordrangerforum.com/4-0-s...erheating.html
AndyWRS is offline   Reply With Quote
Old 05-06-2012, 10:47 PM   #3
Well andy. I am about tempted. Its making me that mad
Old 05-06-2012, 10:48 PM   #4
I'm Your Huckleberry
Is you're electric fan working? Are you running only water or proper 70/30 antifreeze mix? Have you tried flushing the radiator?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-06-2012, 10:55 PM   #5
Metal Roofing
The link i provided may be of interest.
my first truck was a 86 ranger, then a 93 then a 03. I had minor issues with mine, i usually sell them around 170k miles and get a new one though.
Old 05-07-2012, 06:46 AM   #6
did you put the new thermostat in correctly? There is a right way and a wrong way.
I assume by this you mean the temp gage is reading normal? Is the cooling system full of coolant? The temp gage will not read correctly if there is no coolant in contact with it.
What prompted you to change the thermo.? Was the condition something that suddenly happened or is it something that happened gradually over time. A sudden event might point to a head gasket problem, a gradual problem may indicate your radiator needs flushing.
Get a radiator/cooling system pressure test done. This will confirm if there is a leak somewhere.
Just currious, if the gage is not indicating an over temp condition how are you determining this?
danpik is offline   Reply With Quote
Old 05-07-2012, 07:42 AM   #7
The thermostat went out rwo months ago. Yes it has the appropriate coolant in. An how i have determined it had to be the thermostat. Is bc the truck over heated the belt came over the heater hose busted on me. I replaced the belt the hose and a sensor.
Old 05-07-2012, 09:34 AM   #8
Learning Things Every Day
Jay 78's Avatar
Rangers never had electric fans. Some guys will convert, with the donor usually being a Taurus.
lilwndrs21, I think every Ranger owner should be a member or a Ranger forum. My forum of choice is TRS. http://www.therangerstation.com
Under Construction
Jay 78 is offline   Reply With Quote
Old 05-07-2012, 06:27 PM   #9
There is a reason I'll never own a Ranger. Two, now.
Thanks.
Old 05-07-2012, 06:59 PM   #10
Do you mean the belt broke or the heater hose broke, or did the belt cause the hose to break? Is your water pump in good condition? If the belt "came over" into the hose, are your pully's in good working order. We still do not know how you are determining the system is overheating.
Unique Ford Ranger Exhaust?? Giles Automotive Repairs 3 07-31-2011 03:37 AM
1998 Ford Ranger Electrical Problem - Turn Signals, 4Wheel Drive Yotta Automotive Repairs 2 04-06-2011 07:59 PM
93 Ford Ranger A/C problem robcourtis Automotive Repairs 1 06-14-2010 10:20 PM
'93 Ford Ranger help Sharpeone Automotive Repairs 9 12-28-2008 09:16 AM
1998 Ford ranger electric problem fmg741 Automotive Repairs 5 09-24-2008 01:24 PM
