#1 |
How much do you need to mix fuel stabilizer when you add it to gas?
I'm going to add some fuel stabilizer to my gas. How much mixing do I need to do? Do you just gently tilt the can or do you need to shake it up? Also, a related question, when I add 2-cycle engine oil mix to gas do I need to shake it up or anything initially, or after it's been sitting a while?
Thanks |
#2 | |
A Little Of Everything
How much do you need to mix fuel stabilizer when you add it to gas?Quote:
| The Following User Says Thank You to DrHicks For This Useful Post: | Deck (11-08-2011) |
| Tags |
fuel stabilizer, gas, gasoline ![]() |
| Display Modes | |
| NM cable and Dual fuel range | edge130 | Electrical | 0 | 11-02-2011 04:48 PM |
| Weed eater will not start? | Jake3333 | Landscaping & Lawn Care | 5 | 01-15-2010 12:50 PM |
| Fuel savings from burner/nozzle reduction | EfficientCanuck | HVAC | 13 | 03-01-2009 08:21 PM |
| Broken Burner Fix | mikelbeck | HVAC | 2 | 01-16-2009 10:05 PM |
| Add electric heat so suppliment fuel oil? | arichard21 | HVAC | 12 | 01-13-2008 11:23 AM |
