How Do You Check For A Leak - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-13-2013, 11:24 PM   #1
ms. emmie's Avatar
I'm not sure how to find where my car is leaking from. It's the hydraulic fan reservoir and it keeps going down. Not sure what to do
ms. emmie is offline   Reply With Quote
Old 09-14-2013, 12:37 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 2,140
deleted due to being totally wrong.....
Old 09-14-2013, 12:47 AM   #3
ms. emmie's Avatar
My book said it uses ATF I have a 2001 Lincoln ls
Old 09-14-2013, 12:58 AM   #4
ms. emmie's Avatar
I even looked it up on all data and a shop thought it was a dual steering pump
Old 09-14-2013, 05:47 AM   #5
Rewards Points: 14,312
I've found tiny leaks in Hydraulic and oil systems by adding what's called Trace.
It's really made for finding leaks in A/C systems.
It's super thin and it's bright red.
Only need a small amount.
I've even found a weeping power steering pump hose by using it.
I used to own a company that repaired machines in factory's and machine shops and often had to find leaking seals and gasket.
Kind of hard to find an oil leak on a beige colored machine using cream water coolant, and light brown oil. The red would show up instantly.
It will also glow under a black light.
http://www.jbtoolsales.com/tracerlin...sion-oil-1-oz/
Old 09-14-2013, 09:27 AM   #6
ms. emmie's Avatar
Wow I will have to look into that. I've to a few people and they just look at my car and are like what's that? Thank you
Old 09-14-2013, 09:44 AM   #7
Take it to the dealer and they will keep changing parts until it stops leaking or you run out of money.
Hardway (09-14-2013)
Old 09-14-2013, 09:49 AM   #8
ms. emmie's Avatar
Old 09-14-2013, 10:38 AM   #9
Rewards Points: 268
Yes, put some tracer dye in the reservoir. Yes, Lincoln LS' use 2 power steering pumps...one for the actual steering, the other powers the cooling fan. A terrible design. I've had to work on dozens upon dozens of those cars over the years. The jaguar engine is great, but it was a poor match with that particular chassis. It's the same setup used in the thunderbird for a few years. Most leaks on those systems were at the rubber to metal hose crimps, but it's just as likely that the fluid cooler is leaking. They liked to combine coolers in those years (as they do now), and it may be leaking its fluid into another system when under pressure.
This car is one of the reasons I wanted to get out of the dealership's shop...I now work on dump trucks, loaders, and garbage trucks. Much easier!
Marqed97 is offline   Reply With Quote
Old 09-14-2013, 10:46 AM   #10
JOATMON
ddawg16's Avatar
Hydraulically powered cooling fan? That is a new one for me.....learn something every day....
Old 09-14-2013, 03:31 PM   #11
Rewards Points: 268
Dawg:
It was (and is) a bad idea. I never understood why they couldn't accomplish the same thing with an electric fan. It's already a cramped space under the hood on those cars. Yuck. I spent 7 years as a Ford master mechanic and I couldn't take it anymore (working on commission). I made the switch to our municipal garage and I love it.
Andy
Old 09-14-2013, 10:58 PM   #12
ms. emmie's Avatar
I just bought it and after reading up on this model year it's the last one to have the hydraulic fan reservoir I can see why. Even a oil change cost more.
Old 09-15-2013, 07:54 AM   #13
raylo32's Avatar
Rewards Points: 1,294
New one for me, too. At first I thought the OP was mistaken but I guess it's so. One thing she could look at is to see if anyone in the aftermarket makes an electric fan conversion kit for her model. I suspect there might not be room to mount one but it can't hurt to do a quick look to see if these are available. Then you could just remove that stupid cooling fan hydraulic system from service. What was Lincoln thinking?
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 09-19-2013, 06:23 PM   #14
bbo
I see there is a youtube vid for converting.
I've one mechanical to elec fan conversions, I don't see how this would be any more difficult.
bbo is offline   Reply With Quote
Mystery - leak or no leak turness Plumbing 4 01-12-2013 07:46 PM
Coil leak after maint check??? Possible??? wraiththe HVAC 11 09-20-2012 06:55 AM
Possible small gas leak in black iron pipes WillK Plumbing 4 01-17-2012 11:07 PM
Replace sump pump check valve its got a leak detyianni Plumbing 4 05-16-2011 05:38 PM
Freon Leak captainron19 HVAC 3 04-16-2010 04:30 PM
