How Do I Change Holden VT Commodore Break Pads - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-11-2011, 12:33 AM   #1
How do i change Holden VT commodore break pads
Can someone please tell me how to change break pads?
Baldhill2007 is offline   Reply With Quote
Old 04-11-2011, 11:00 AM   #2
Household Handyman
Rewards Points: 1,408
I'm thinking you are asking about "brake" pads, as in the brake/stopping system of a vehicle. A Holden, if I remember correctly is an Australian GM built vehicle. This should be moved to the "Automotive Repair" section.
Old 04-11-2011, 11:47 AM   #3
Rewards Points: 5,336
You should pick up one of those Chilton or Haynes manuals if you're working on the car to get the specifics for your model. There are other things associated with a pad change, especially if it's the front wheels on a rear wheel drive car.
Ron
Old 04-11-2011, 05:17 PM   #4
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
A Holden is a GM, it should work the same way any other GM works.
remove the wheel
remove the rattle guard (that giant clip)
pull out the rubber gromets and use an allen wrench to take out the caliper slide pins
get rid of caliper (put it on an upside down bucket)
yank the pads out.
Find out what the torque specs are before you put it back together though! The caliper slide pins will have a relatively low torque spec.
CoconutPete is offline   Reply With Quote
