How To Bleed Fuel Line For 1999 VW Passat 1.8T? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 05-09-2014, 10:57 PM   #1
How to bleed fuel line for 1999 VW passat 1.8T?
I need to know in detail which line to disconnect or where the valve is located. I ran completely out of gas and now that it has gas in it, it sputters so I am trying this but I don't know how.
russell6 is offline   Reply With Quote
Old 05-10-2014, 10:32 AM   #2
ukrkoz's Avatar
Rewards Points: 940
It likely sucked some junk from tank onto the fuel pump filter. There should be a pre-filter in the pump housing. Pull pump and replace or clean, and replace inline fuel filter. No air gets trapped in fuel lines.
ukrkoz is offline   Reply With Quote
Old 05-11-2014, 12:05 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,038
That era of fuel systems is a return style and should never get vacuum locked like that.
Sounds like it is trash on the pick up or the baffle got stuck and is run dry.
Capacity loss with line size Einride HVAC 1 06-29-2009 04:10 PM
Broken Burner Fix mikelbeck HVAC 2 01-16-2009 10:05 PM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 08:53 AM
fuel leak where filter line meets tank line sonofthetonsured Automotive Repairs 2 04-22-2008 09:11 AM
air in fuel line pingers7 HVAC 2 01-28-2007 07:41 PM
