Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-20-2012, 02:44 PM   #1
Horn installation- sparking at ground?
Im installing an oohga horn and have one terminal of the switch going to an "add a fuse" (size 10 fuse) and the other terminal going directly to the horn. There is only the one singular wire coming out of the horn.
I am mounting the metal plate/base of the horn in order to ground it, however before I bolted it on all the way I barely touched it to the grounded bolts just to test the horn and when I pressed the horn button I got sparks coming from the grounded bolts.
Whats the issue here??
zoiberg137 is offline   Reply With Quote
Old 12-20-2012, 03:48 PM   #2
47_47's Avatar
The poor ground is the problem. It took less current to jump the air gap than to sound the horn.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is online now   Reply With Quote
Old 12-20-2012, 09:49 PM   #3
what he said, clean and tighten that ground
D-rock is offline   Reply With Quote
Old 12-22-2012, 12:03 AM   #4
make a good connection and you wont have sparks.
redman88 is offline   Reply With Quote
Old 12-22-2012, 08:02 PM   #5
World's Tallest Midget
Mort's Avatar
...that, and disconnect your battery when you're working on anything electrical.
Mort is offline   Reply With Quote
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 11:58 PM
Multiple Ground Rods, help Ralph III Electrical 72 02-14-2012 10:31 PM
Ground Rod Installation capt2 Electrical 2 10-10-2007 07:56 AM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
