-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   Horn installation- sparking at ground? (http://www.diychatroom.com/f46/horn-installation-sparking-ground-167003/)
zoiberg137 12-20-2012 02:44 PM
Im installing an oohga horn and have one terminal of the switch going to an "add a fuse" (size 10 fuse) and the other terminal going directly to the horn. There is only the one singular wire coming out of the horn.
I am mounting the metal plate/base of the horn in order to ground it, however before I bolted it on all the way I barely touched it to the grounded bolts just to test the horn and when I pressed the horn button I got sparks coming from the grounded bolts.
Whats the issue here??
47_47 12-20-2012 03:48 PM
The poor ground is the problem. It took less current to jump the air gap than to sound the horn.
D-rock 12-20-2012 09:49 PM
what he said, clean and tighten that ground
redman88 12-22-2012 12:03 AM
make a good connection and you wont have sparks.
Mort 12-22-2012 08:02 PM
...that, and disconnect your battery when you're working on anything electrical.
