Hood Hinge Pin Removal? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-23-2014, 09:52 AM   #1
Rewards Points: 260
Hood hinge pin removal?
Hi all. I have a 93 Camry that I'm trying to replace the hood lift supports on. I got the passenger side done last night, but the driver side requires you to remove the pin that holds the two brackets together. One of the brackets connects to a large electrical plug coming from the firewall acting as a support for it and the other attaches to the inner fender, which is the bottom support connection for the lift support.
The passenger side came with a new bracket, but apparently you have to reuse the driver side. The only problem is that there is a pressed pin holding the two brackets together on the driver side. Any idea how I could get this pin out? It gave me gray hair last night. Thanks!
Jesse
jpearson311 is offline   Reply With Quote
Old 07-23-2014, 01:46 PM   #2
Rewards Points: 392
A picture might be helpful illustrating what you're working on. I can tell you that if you're driving out a pin, it's probabably not going to go to well without removing the assembly from the car.
rustyjames is offline   Reply With Quote
Old 07-23-2014, 01:51 PM   #3
Rewards Points: 260
Ok, I don't have a photo now, but I'll try to post one later tonight. And the assembly is already removed from the car.
Jesse
Self closing hinge removal azhomeowner Remodeling 5 08-07-2012 02:59 AM
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 08:08 PM
range hood opening is bigger than range hood jacks16 HVAC 2 06-23-2011 07:19 AM
door hinge into a plaster wall? dbpass Remodeling 1 05-04-2011 12:49 AM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 08:00 PM
