Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-22-2013, 11:11 AM   #1
Honda magna 700 cc 1986
How do I remove carbs
snowman21385 is offline   Reply With Quote
Old 02-22-2013, 12:49 PM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,... Very carefully,..... After ya remove All the stuff that's in yer way....
Old 02-22-2013, 04:34 PM   #3
5 second search on Google
http://www.youtube.com/watch?v=uh-UOplGXzU
TheBobmanNH is online now   Reply With Quote
Old 02-22-2013, 10:33 PM   #4
Now come on Bob we do not get many motorcycle questions around here, did you have to answer it that fast.
paintdrying is offline   Reply With Quote
Old 02-25-2013, 11:40 AM   #5
Sorry, we can chat bikes anyway if you want.
My first was an '81 Yamaha XS850, Midnight Special. Triple cylinder. I miss that bike.
Old 02-25-2013, 12:36 PM   #6
It will idle with a full chock but that's it is there a cleaner I can run through to try n help
Old 02-25-2013, 12:49 PM   #7
There are a million chemicals out there, and depending on how bad things are they may help, but you'd be a lot better off pulling the carbs, however difficult it is.
Old 02-25-2013, 04:03 PM   #8
No, a cleaner will not work at this stage, you will have to pull them. My first bike was a 1978 honda cb750. I still look at those bikes as new.
Old 02-25-2013, 05:23 PM   #9
Bondo's Avatar
Ayuh,.... Mine was a '72....
Bought it Wrecked, 'n built is back up as a Cafe,...
Lowered front-end, dual disc's,...
I'm guessin' the Op's carbs need Rebuildin'...
Old 02-25-2013, 05:45 PM   #10
Yes carbs need rebuilt I live n south bend IN any one know where to take it
Old 02-25-2013, 07:19 PM   #11
MarginallyQualified
You're not going to find a shop that wants to take on that job.
There is just no percentage in it.
What you need is an old V4 enthusiast who might trade his time.
Start here: www.sabmag.org
Your next best bet is old gear generalist...
who needs some info on the V4 carbs in particular.
Start here:http://www.sabmag.org/Sabre-Magna%20FAQ%20v2.htm
TarheelTerp is online now   Reply With Quote
Old 02-25-2013, 08:04 PM   #12
Any motorcycle shop should so it. You may not want to pay the price to get them cleaned up though. Could exceed the value of that old of a bike pretty quick
cjm94 is offline   Reply With Quote
Old 02-25-2013, 08:22 PM   #13
firehawkmph's Avatar
Try just taking the bowls off and take out the pilot jets and clean them. They have a tiny hole that is easily plugged by dried up gas. Usually best to take the carbs off, makes it easier to get the bowls off and clean up inside. Bowls will usually have some dried up gunk in them. Pilot jets normally come out with a small straight tipped screwdriver. You can unplug them with a couple of fine strands of copper wire. By fine, I mean fine. Take a piece of speaker wire and strip the insulation off so you have about 3" of bare stranded wire. Take two strands out of the bunch and twist them together. Once you get the pilot jets out, slowly twist the wire back and forth as you gently push it through the hole in the pilot jet. You can spray some carb cleaner through the hole once you break through with the wire. Not very difficult to do with the carbs off. Just take your time.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 02-25-2013, 08:29 PM   #14
Got carbs all most off can't find anything holding them on but they won't move any help
Old 02-25-2013, 10:36 PM   #15
You got them out of the boots?
1995 Honda Odyssey Coolant in Reservoir very dark amodoko Automotive Repairs 12 01-06-2013 08:23 PM
Honda 3000is portable generator RickDyke Electrical 1 08-28-2012 12:45 AM
Is Honda Generator worth the cost? Dave_T Electrical 2 11-22-2011 10:38 AM
Honda pressure washer help woofie General Discussion 1 08-25-2009 04:40 PM
Honda Civic Catalytic Converter cibula11 Automotive Repairs 3 08-27-2008 07:50 AM
