Honda GX120 Engine On A 2" Water Pump - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-19-2009, 03:07 PM   #1
Tom B
Honda GX120 engine on a 2" water pump
We have a the above mentioned Honda engine attached to a 2'' water pump used to pump out the holding tanks of boats. For a while now when we start it will run for about a minute, start running rough and then stall out. It can be restarted again, right away, and the same thing will happen. We have installed a new filter in the tank, replaced the carburetor, removed the head to clean and inspect the valves (they look great) reassembled everything and the same problem exist. I don't know where to go from here. This problem started out slow and has gotten progressively worse to where it is today. After a few starts the spark plug is fouled black like it may be running too rich.
tomb215 is offline   Reply With Quote
Old 04-20-2009, 05:24 PM   #2
weak ign. system maybe,
gotboost is offline   Reply With Quote
Old 04-20-2009, 06:02 PM   #3
BIGRED
Rewards Points: 252
Could be a weak plug, an incorrect plug heat range, or since you say it is fouled black it could be running rich. Try closing the hi-speed screw 1/2 a turn. If it doesn't work open it right back up. Then try opening the hi-speed screw 1/2 a turn and try it. The plug appearance should tell you right away whether it is rich or lean. Non-sooted to black dry soot indicates a lean mixture. Wet to wet sooted means way to rich. Hondas do not require very much choking even from a cold start.
Grampa Bud is offline   Reply With Quote
Old 04-20-2009, 07:21 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 358
Ayuh,... Disconnect the Low Oil Shut-down switch,+ Try it....
Old 04-24-2009, 08:21 AM   #5
Fuel tank cap
Have you tried running it with the fuel cap loose? I had the same issue was a air check failure in the gas cap.
shortlid is offline   Reply With Quote
Old 04-25-2009, 06:07 PM   #6
Tom B
Honda GX120
It has been pretty well pin pointed to the ignition coil. Would get a complete break down as soon as a load was applied. Engine would shut down and could be restarted again on first pull. As soon as a load was applied it would shut down again. New coil will be ordered Monday. Thanks to all for you advice and assistance.
Will let all know if the problem is resolved with the new coil.
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Water Powered Sump Pump acuteot Plumbing 7 11-23-2008 10:40 PM
new owner---old jet water pump rise n' shine Plumbing 12 09-27-2008 02:39 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
