#1 |
honda cb 450 1973
I have tried every thing to get it running,drained fuel,new carbs,new points,battery. It is a very clean bike I am 2nd owner. I get it to run for a few seconds then just dies,Any suggestions.
#2 |
I'm Your Huckleberry
honda cb 450 1973
Fuel filter? Did you spray something high octane such as carb cleaner into the carb to keep it running?
I had a 1971 cb 175 and a cb 750, plus a slew of dirtbikes and one moped. . All of them needed the occasional fuel system clean out.
Thanks. |
#3 |
honda cb 450 1973
yes cleaned the carbs kits and all
#4 |
honda cb 450 1973
And is it the correct battery? 12 volt I think is correct. I bought the 175, it had a 6 volt battery in it and wouldn't start. I bought the correct 12 volt and instantly it cranked and ran just fine.
Thanks. |
#5 |
honda cb 450 1973
I'm no expert mechanic but is the float working properly? You may need to clean it all again and make sure there is a clear fuel line, not clogged. It sounds to me as if it's a lack of fuel issue, possibly a carb adjustment.
Thanks. |
#6 |
honda cb 450 1973
yes purchased from motor cycle shop.I saw one entry adjust valves do you think this is it
#7 |
honda cb 450 1973
I doubt the valves are causing this issue. It is most likely fuel. The carbs being cleaned also need balanced. That is somewhat of an art and requires a special piece of equipment, a manometer. If you changed carbs and messed with the linkage between them, then I suspect this is the problem.
#8 |
Member at Large
honda cb 450 1973
Might consider checking the exhaust pipe/pipes for critter nest.
Have seen that one more than once. |
| The Following User Says Thank You to oldpaintdoc For This Useful Post: | Marty1Mc (07-08-2012) |
#9 |
Member at Large
honda cb 450 1973
Sorry double post.
#10 | |
A Little Of Everything
honda cb 450 1973Quote:
Are the carbs brand new, or rebuilt, or cleaned? I'm a bit confused. If they're new, they probably are not adjusted properly. Even so, it sounds as though your carb floats are not letting the needle valve open. I'll probably get in trouble for linking this site, but you're going to get far more information about your bike from the site below. http://www.hondatwins.net/forum/inde...56e53b46853ed2 |
| The Following User Says Thank You to DrHicks For This Useful Post: | oh'mike (07-08-2012) |
#11 |
Super Moderator
honda cb 450 1973
We are here to offer the best help---that is what you are doing---
OP--keep us informed--A lot of us spent many happy hours on Hondas from that era.
New members: Adding your location to your profile helps in many ways.--M-- |
#12 | |
![]() Currently I've got a '73 CL350 sitting in my garage. I'm trying to get the title problems solved. But if I do, I'm going to be the coolest old fart on 2 wheels! ![]() My "regular" rider is an '05 Kawasaki 1500 Vulcan Classic. A Harley Wannabe. It's smooooooooth... Last edited by DrHicks; 07-08-2012 at 07:27 PM. |
#13 |
Super Moderator
honda cb 450 1973
I learned on a Honda 50----and had a 90 for use off the road---it was a street bike but never had plates--Your bike would have been a dream---nice ride--I hope you can get a title---
| Display Modes | |
| Is Honda Generator worth the cost? | Dave_T | Electrical | 2 | 11-22-2011 10:38 AM |
| 1970 Honda cb 450 idle problems | cowboykp | Automotive Repairs | 15 | 11-24-2010 07:02 PM |
| Honda EX650 Generator | spanishgrass | Tools | 1 | 11-26-2009 01:32 PM |
| Honda Civic Catalytic Converter | cibula11 | Automotive Repairs | 3 | 08-27-2008 07:50 AM |
| 1973 Honda 450 | Murphy | Automotive Repairs | 5 | 07-25-2008 09:58 PM |
