Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-17-2010, 10:34 PM   #1
GeraldR's Avatar
High Oil Pressure reading, knocking engine
I've got a well maintained engine that now has a bearing knock, lifter tick, yet I installed today, a manual test oil pressure gauge and it's running 3o-7o psi. No leaks, no other issues, but engine sounds like it has no oil pressure in it?????
GeraldR is offline   Reply With Quote
Old 07-23-2010, 05:02 PM   #2
i have built half a dozen motors and worked in a shop when i was younger. never once have i seen this. are you certain what you have is rod knock?
racebum is offline   Reply With Quote
Old 07-23-2010, 05:16 PM   #3
may have a blockage after where you tested for pressure , so you get a higher reading there and its staving on the other side of it ???
comp is offline   Reply With Quote
Old 07-23-2010, 05:22 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Bearing knock, lifter tick or both?
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 07-24-2010, 08:43 PM   #5
GeraldR's Avatar
Yes, this is a definite lifter/tappet tic along with the sound of a bearing rumble. I've pulled test guage off, ran it and can spray oil a good 4 feet away.
Just some how maaaaaayybe is did the viscosity drop?? see that before with fuel flood... problem is, I don't have fuel flood.
Old 07-24-2010, 08:45 PM   #6
did you look in the oil cap hole to see if there is oil flowing ??
Old 07-24-2010, 08:54 PM   #7
GeraldR's Avatar
Yep, it'll shoot out of cap with increase rpm's . My first thoughts too, is it getting oil up to top. looks real good flow there. I've removed the valve covers, and this engine is very very clean, no sludge, no tar, no boogers, no milkshakes or any sign of oil system problems. I've drivin this 99,000 mile car for the last 7,000 miles, no indication of anything, it's had 2 oil changes, and just perfect performance. . .'til now.
Old 07-24-2010, 10:33 PM   #8
that sucks,,,,,,,,next thing to do is drain the pan and look for material and cut open the filter and inspect it
Old 08-02-2010, 05:56 PM   #9
agree with looking for metal flakes in the oil. another thought is timing. if your timing belt skips a tooth or the chain stretches to hell and back along and or off ignition timing you can create what sounds like a knock. i would check cam to piston timing and ignition timing. a blocked oil passage in theory could raise gauge pressure but it would be extremely rare to see, not that that means it can't happen
Questions about water pressure regulation.. MrSimmonsSr Plumbing 20 11-30-2012 10:43 PM
Pool Motor Wiring Assistance tazmajazz Electrical 18 05-16-2008 11:42 PM
Running a secondary high pressure line Randell Tarin General Discussion 6 02-18-2008 12:39 PM
High pressure bjr23 Plumbing 1 03-27-2007 08:24 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 10:04 PM
