Hey You! Need Advice Auto Gurus... - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-23-2007, 05:40 PM   #1
Lightbulb
Hey you! Need advice auto gurus...
Okay, so this isn't really about automotive repairs as the forum is titled. What I want to do is take an old extended cargo van (3/4 or 1 ton) and turn it into a "van truck", like this little photo-manipulation I made shows:
By now you're either thinking, "wow, this is one helluva cool idea." Or "wow, that's one of the stupidest things I've ever heard of." Regardless of what you think, it's what I want to do. I need something to keep myself busy and work on.
Now if I could have your input...
1. What should I use to saw off the cargo area, a Sawzall or something?
2. I'm don't know how to weld, so should I save the very back of it (where the doors are) and bring it to a welder to have them close the cab off?
3. Am I correct on the following 'steps' to pursue this?
Start -- Disconnect battery --> Gut interior --> Draw markings where to cut --> Cut into small sections with reciprocating saw --> Save doors and back area so it can be welded onto cab --> Bring to welding shop to have them close off the cab -- Done
andrgo is offline   Reply With Quote
Old 08-23-2007, 06:53 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Sounds like you have a firm grasp of what's involved
The sawsall will work well, but get a few specialty blades
I forget exactly which ones I use for this, but they are always labeled well
If you are re-welding I'd go for a "smooth cut metal" rather than a quick cut metal
Expect to break a few, but with good blades and some care you might not
It should cut easier than you think (if you've never done it before)
slickshift is offline   Reply With Quote
Old 08-23-2007, 10:51 PM   #3
General Contractor
joasis's Avatar
Used to be a company in Oklahoma that did these as a conversion, but they started with a 1 ton chassis, with bed, and then placed a van body, cut about like you have it in the pictures. This was before the growth of trucks into the crew cabs of today....I bet I haven't seen one on the road in 10 or 15 years....some even had the fold down van seat/bed.....
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 08-24-2007, 06:38 AM   #4
zel
Rewards Points: 150
Send a message via AIM to zel
Look for a truck and van that share the same frame, like maybe a Ranger. Then you might be able to just use the bed from the Ranger, rather then trying to build the bed with the left over metal from the back lower half of the truck.
zel is offline   Reply With Quote
Help Repair Garage Wall - Advice RandomJustice Building & Construction 8 07-28-2007 10:02 PM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 10:16 PM
Painting over panelling - seek advice deb14905 Painting 13 10-13-2006 07:26 PM
bathroom wall advice bigbrad123 General DIY Discussions 9 06-07-2006 07:26 AM
