Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-03-2012, 10:00 AM   #1
Help me clean out my fuel injectors!
Hi, I have a 1995 toyota tacoma which has sat idle for six years. It is now registered and back on the road. Engine bucks prior to shifting my gears. (manual transmission). I have used chemtrol and gumout additive to gasoline. I am looking for a spray product to use in the air intake that won't damage the fuel injectors. I know you guys can help me. Can I use a little carb & choke cleaner?
Thanks,
Bill
billpb1222 is offline   Reply With Quote
Old 09-03-2012, 10:41 AM   #2
ukrkoz's Avatar
prolly, and you need to have adapters to put liquid into fuel stream, as in - gas line. When you have those installed, use Techron or Seafoam.
Or, you can do one at a time:
http://www.youtube.com/watch?v=VFJlTfHyrUk
Or
http://www.youtube.com/watch?v=bKGI9N_yWd0
ukrkoz is offline   Reply With Quote
Old 09-05-2012, 07:38 AM   #3
I would also consider other issues than a clogged injector that could be causing this problem. I would clean the major sensor connectors (Throttle position, Mass Air Flow, MAP (manifold absolute pressure), Cam angle sensor, ignitor,etc.) as well as the injector connectors. After sitting 6 yrs, the normal humidity in the air can corrode the connections and you will go nuts trying to find the gremlins this alone can cause.
I would also ohm out the injectors. I am not sure whether your injectors are high or low impedance, but put an ohm meter across the injector terminals (do this while the connector is off for cleaning), and see what it measures. Write down each and notice if one is significantly above/below the others.
Marty1Mc is offline   Reply With Quote
Old 10-04-2012, 10:33 AM   #4
Doyle Sumrall
DoyleSumrall's Avatar
Try using the Chevron Fuel Injector cleaner with techron. That stuff has worked great for me.
DoyleSumrall is offline   Reply With Quote
Old 10-04-2012, 06:40 PM   #5
Fixer-'til-broker
DIYtestdummy's Avatar
6 years? Did you empty the fuel tank and clean it out before running it? Old gasoline can cause all sorts of problems.
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
B-12 Chemtool versus SeaFoam DrHicks Automotive Repairs 16 10-01-2012 09:57 PM
Best way to clean up metal cap with build up dirt? Andee77 Painting 1 07-27-2012 10:19 PM
Looking for ideas...drywalling a clean out MLayden Drywall & Plaster 1 06-15-2012 12:14 PM
How often do you clean your Paslodes Bearcreek Tools 1 08-24-2009 10:00 AM
Keeping Hardwood/Bamboo Flooring Clean? brandon272 Flooring 2 07-08-2009 10:39 AM
