Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-21-2012, 07:27 PM   #1
hello..half heat
i have a dodge 02 ram 1500 mil came on noticed i had heat better on passenger side than on driver side.noticed i had radiator leak had the radiator replaced light still on.leak fixed but still same heat..someone said try the fuse well the fuse did put the light out but the heat is the same good and hot on pass side cooler on drivers...anyone think it could poossibly be as simple as the thermsathat..thanks in advance for any ideas..patti
pateez1 is offline   Reply With Quote
Old 02-21-2012, 07:56 PM   #2
Disabled wood vet
titanoman's Avatar
hello..half heat
I can't understand half of what you're saying, but if you have good heat on one side, but not the other, it's probably in the duct work. "It" being an obstruction or a flapper that isn't flapping.
titanoman is offline   Reply With Quote
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 06:38 AM
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 09:30 AM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 04:57 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
